I mean, Wouldn't it be possible to give a gate pulse on triac directly? I have seen in many phase control application circuits like fan speed control,the usage of diacs to trigger a triac.
1The pulse generated by a DIAC is synced with mains automagically. You don't need a DIAC If you feel like doing the synchronization manually or don't care. – Oleg Mazurov Feb 01 '15 at 18:06
2It is possible to give a gate pulse on triac directly by using something that produces gate pulses. A DIAC is just such a device and is doing just what you suggest. A TRIAC gate is not designed to switch at a tightly controlled voltage or current and if a rising voltage source is connected to the gate the TRIAC will turn on in a "soft" and ill defined manner and time location. The DIAC allows input voltage to rise to a wellish defined level and then dumps a more than high enough voltage, energy source (capacitor) into the gate. ~~~ Dog on long chain - left to itself you may get bitten .... – Russell McMahon Feb 01 '15 at 21:24
.... at extreme length of chain and retreat. If a "handler" restrains the dog until you are well inside chan length the dog can devote all its energy to you. – Russell McMahon Feb 01 '15 at 21:25
See http://en.wikipedia.org/wiki/DIAC for a diagram of the breakdown behaviour of a Diac.
As you can see there, a Diac is non conductive up to a certain breakdown voltage, above it becomes conductive, until the current drops below a threshold value.
In short, the diac is forming the pulse that is needed to trigger the triac.
- 618
- 3
- 7
Yes you can, however, if you control with DC, I recommend using an opto-isolator (like a moc3041) to keep the dc grounds isolated from the AC.
But here is the simple switch method:
- 1,033
- 6
- 8
