Does anyone know how to model a depletion mode N channel MOSFET in spice?
I have looked online however the majority of resources have shown how to model a depletion type or enhancement type. I specifically want to model a FET that is fully on when there is a 0 Vgs voltage.
Resources i've looked at
secretformula
  • 288
  • Can you explain the distinction you're making between "mode" and "type" in this context? – Dave Tweed Jan 21 '15 at 19:06
  • @DaveTweed In this context I am looking to model a fet where when Vgs is 0, current will flow freely between the drain and source. When Vgs > Vth the channel will close an only leakage will flow. Does that explain? – secretformula Jan 21 '15 at 19:14
  • Can you give a link to the material you found about depletion "type" MOSFETs? – The Photon Jan 21 '15 at 19:17
  • @ThePhoton the second one mentions depletion mode devices be I believe it's just referring to p channel fets. Also please tell me if there's a better nomenclature for these parts / behaviors – secretformula Jan 21 '15 at 19:24
The solution is given in the LTSpice help file you linked:
VTO is positive (negative) for enhancement mode and negative (positive) for depletion mode N-channel (P-channel) devices.
For an NMOS FET, if VTO is positive, you have an enhancement mode device. If VTO is negative, then you have a depletion mode device.
For a depletion mode NMOS FET, with 0 Vgs the channel will conduct. Vgs must be pulled below 0 V in order to cut off the channel. In SPICE this behavior is represented by a negative threshold voltage, controlled by the VTO parameter.
From your comments, though, you want
To get this behavior, you need a p-channel depletion mode MOSFET. An n-channel FET doesn't work this way.
The Photon
  • 126,425
  • 159
  • 304
