I'm having trouble with a circuit I designed and I'm hoping someone here may help me fix it.
I've successfully used the circuit below a few times. It was proposed by Russel McMahon in this answer. It let's the user power up a circuit by closing SW1 (Go!) long enough so that the MCU then can keep the circuit powered by keeping the signal HIGH_TO_RUN
high. To turn it off, the MCU just have to bring the same signal low.
This time I'm using two NiMH AA cells (~2.5V) to power a boost DC/DC converter based on the MC33063 IC which in turn brings the voltage up to ~5V and deliver about 125mA to an ATmega328P circuit. The circuit is the following.
The problem is that the minimum input voltage on my MC33063 is about 2.5V and Q1 is dropping it below that, to about 2.0V.
So, my questions are:
How can I modify the circuit so that I can deliver ~200mA@5V to my load from the same two NiMH AA cells?
Can I replace Q1 with an P-Channel MOSFET (such as the IRF9530) to decrease the voltage drop on the transistor? What changes to the circuit should be made then?
Note: The linked datasheet says that the minimum input voltage for the MC33063 is 3.0V, but I'm pretty sure there are variants out there that take less voltage (1.8, 2.0 and 2.5V if I'm not mistaken). I'm pretty sure mine is the 2.5V variant (at least I've tested it).
