this is an extension of this question:
Why aren't ferrite rod antennas used in WiFi?
if you don't want to go through the previous question, then basically i was asking if we can loop wifi antennas around a ferrimagnetic cores, so as to concentrate the fields and get a higher gain.
the same way in AM radios, we loop wires around a soft ferrite to concentrate the fields, to act as the receiving antenna. greatly reducing what would probably be hundreds of meters long to just a few inches.
well, since then, i've been told that ferrite just can't hold magnetic fields quick enough in those frequencies and they act as noise dampeners. "noise" being the high frequencies in GHz... so i turned to supermalloys.
http://en.wikipedia.org/wiki/Supermalloy
i'm not entirely sure if supermalloys are a good way to go, though... i've skimmed through abstracts of articles of it being used in GHz, but not as cores of loop antennas. then there's also the issue of it being a good conductor, which would lead to A LOT of hysteresis loss...
but putting aside hysteresis loss, would it make a good core??
please point out where i'm wrong here...
