For example, the passband of a LC resonant circuit is the differences of frequency at +3db and -3db.
Why do we prefer dB?
Many processes in nature are either of logarithmic nature (like human senses) or have a great dynamic range.
Describing them on a logarithmic scale and expressing differences in dB has several advantages:
Here's another video about it.
In many cases, voltage ratios are expressed in terms of dB rather than absolute numbers because there are many relationships which end up being linear when expressed in terms of dB. It is simpler, for example, to say that an N-stage low-pass filter will attenuate frequencies above the cutoff by \$(6 \times N) \frac{dB}{octave}\$ than it is to say that it will attenuate frequencies above the cutoff by a ratio of \$({\frac{f_c}{f}})^N\$.
dB is useful since it is a relative expression. +/-3dB is a doubling or halving of power.
dB are often used because the human senses have a logarithmic response, to increase the dynamic range.
Around 3dB gives a sensation of doubling or halving the stimulus, as well as doubling or halving the physical value. That value seems to apply to all human senses, and is one reason why 3dB is so ubiquitous. Psychophysics, a branch of experimental psychology, has a long history of investigating this stuff. The minimal amount of change that can be detected is around 1dB (the Just Noticeable Difference or JND). 0dB is the absolute threshold, below which the stimulus isn't detected.
