I want to use a USB connection with the ATmega32u4, but there are 6 pins in the datasheet (http://www.atmel.com/Images/doc7766.pdf) associated with the USB. I don't know which ones connect to the generic USB connections. Can someone show me how they are setup?
Asked
Active
Viewed 5,047 times
Section 21, "USB controller", subsection 21.3, "Typical Application Implementation", of the datasheet shows methods of connecting the device along with associated components to USB in various bus- or self-powered configurations.
Ignacio Vazquez-Abrams
- 48,282
- 4
- 73
- 102
Thank you! But can you tell me why the USB has five connections? What is the fifth one at the bottom of the diagram do? – Jdude2345 Jan 04 '15 at 00:03
1http://electronics.stackexchange.com/questions/35462/why-does-micro-usb-2-0-have-5-pins-when-the-a-type-only-has-4 – Ignacio Vazquez-Abrams Jan 04 '15 at 00:07
If you are not talking about the OTG ID pin (which you can leave unconnected), then give the name of the signal you are asking about. – Chris Stratton Jan 04 '15 at 03:53
To connect this ATmega on USB, you should connect:
Pin 3 (D-) with a 22 Ohm resistor in serial connected at pin 2(D-) of USB
Pin 4 (D+) with a 22 Ohm resistor in serial connected at pin 3 (D+) of USB
pin 35 (GND) connected at pin 1 of (GND)USB
pin 34 (VCC) connected at pin 4 of (VCC)USB
