Everybody knows its easy to develop a proof of concept for an embedded device on a rasbperry pi or even a PC, although when it comes down to choosing a microprocessor for your product, it is difficult to be sure your choice will allow your concept to work optimally.
I currently have a media streaming project successfully working on the raspberry pi, although the pi is much to big and bulky for it to be proper as an end device. Also it is stated that the end device is custom. I'm having a hard time finding confidence in processors that I can use.
What is a good process as to finding out if a processor is powerful enough to run my application?
Basically my requirements are:
- USB host or embedded TCP/IP stack for WiFi operation
- I2S/PCM media protocol
- I2C for peripheral configuration
Finding chips with those properties is very very simply. It honestly couldn't be simpler. The issue is being able to tell if the chip is fast enough, processing and operation-wise.
I've looked at the LPC4337 quite a bit and I feel like it would be suitable although the development environment is giving me quite a bit of trouble, for that reason I'm still looking around, which led me to the CC3200 from Texas Instruments, although that controller only runs at 80 MHz and I'm not sure if that will be strong enough for real-time media streaming.
What are some steps to make sure a processor is fast enough for my application? Like how do I know if an 80 MHz processor will be good enough or do I need something on the order of 204 MHz or even higher?
