Schottky diode have a low forward voltage drop (typically \$0.15-0.45V\$) and very fast switching action, as compared to traditional diode, which typically have a \$0.7V\$ voltage drop (Silicon diodes). What is then the advantage of traditional diode as compared to Schottky diodes?
Asked
Active
Viewed 3,729 times
1They're cheaper! – Nick Johnson Dec 18 '14 at 16:43
Not enough for an answer, but in one application when I used diodes for a simple bridge rectifier, traditional silicon diodes proved to be better due to their higher voltage drop, because the result was lower power dissipation in the voltage regulator. – AndrejaKo Dec 18 '14 at 16:49
Schottky: More costly. If you need high voltage, the Vf advantage quickly decreases (20V <10ns 1N5817 0.45V@1A 40V 1N5819 0.6V@1A vs. 400V 50ns UF4004 1.0V@1A) so it pretty much disappears by 100V. Reverse leakage can be very high, esp. at high temperatures. Ultrafast high voltage diodes and gold doped diodes can be an advantage. – Spehro Pefhany Dec 18 '14 at 19:26
Full semiconductor junction diodes have much lower reverse leakage. Take a look at a Schottky diode datasheet, and note the reverse leakage, particularly at maximum working temperature.
Semiconductor junction diodes are also available at much higher reverse voltages.
Alexandre Willame
- 577
- 5
- 10
Olin Lathrop
- 310,974
- 36
- 428
- 915
Schottky diodes typically have much higher reverse leakage currents than traditional diodes.
Dave Tweed
- 168,369
- 17
- 228
- 393
Hmm I assume the leakage current goes hand in hand with the lower barrier height. (It takes less thermal energy to make a carrier.) – George Herold Dec 18 '14 at 17:32
