Project specifications
- This is an **Arduino** project - This is supposed to be internationally applicableI am working on a home automation project which might go into smaller production. The project is wireless and the connections would be managed as followed:
- You would have multiple slave nodes, and one master node in the house.
- All of these nodes would be transmitting and receiving data. E.G.
- Receive: command to switch relay, turn on the AC etc.
- Transmit: optocoupler data to see if a light is on, temperature etc.
Bands
I have 2 band options:- 2.4 GHz band
- 433 MHz band
2.4 GHz
Pros:- Big data transfer rate(not really that important)
- Cheap transceivers with antennas available here
Cons:
- Small range, solved by making each node a repeater. It bounces the signal if it isn't its, but writes down the packet id so if another node bounces the packet the node wouldn't get stuck in an endless loop)
- A lot of interference
Questions:
- Do any government regulations limit duty cycles for this band?
- Would it be that badly affected with other wireless networks?
- Would the other signals make the signal hard to read(I have never worked with this band before)?
- Would the repeater idea work?
433 MHz
Pros:- Big range
- Good wall penetration
- Little interference
Cons:
- Really freaking expensive transceivers
- If I would use no transceivers, but 1 receiver and 1 transmitter(cheaper), I would need 2 antennae, and it would cost me about the same as the 2.4 GHz transceiver w/ antenna
Questions:
- Would the 1 receiver + 1 transmitter interfere badly with each other?
- Is this band crowded?
