The example code
- initializes an asynchronous timer that is fired every second
- sets two ports as outputs (PA4, PA6 - LEDs connected)
- the timer ISR toggles pin PA4
- permanently sets pin PA6 to 1 in the main while() loop
If pin PA6 is toggled using
PORTA |= (1 << PA6);
everything works as expected. The LED on pin PA4 is toggled exactly every second. However, if the port is set like this
PORTA |= (1 << PinNumber);
the pin PA4 is only toggled very sporadically (observed up to 22 seconds between toggles). This indicates for me that for some reason the controller is either "busy" or the overflow ISR flag isn't set at all.
EDIT: If I add some other cycle intensive code like a _delay_us(10); the situation improves in that way that les and less interrupts will be missing the longer the delay. This makes sense if we assume that the pin toggle operation is at some point somehow blocking ISR entry.
Since the ISR execution should always take precedence over the code in the main loop, I don't understand why this can happen and how exactly it makes a difference if the pin number is passed as a constant or as a variable.
I understand that the compiler can probably perform some nice optimization if a constant is used, but using a variable shouldn't result in some ISR-blocking code.
This is on GCC 4.8.1.
#include "stdlib.h"
#include "avr/interrupt.h"
uint8_t PinNumber;
// asynch ISR with external clock source, fires every second
ISR (TIMER2_OVF_vect) {
PORTA ^= (1 << PA4);
int main(void) {
DDRA |= (1 << PA6) | (1 << PA4); // set PA6 and PA4 as output
PinNumber = PA6; // variable that just holds PA6 for demonstration
cli(); // global interrupt disable during init
ASSR |= (1<<AS2); // Asynchronous Timer/Counter2 from external clock
TCNT2 = 0x00;
OCR2A = 0x00;
OCR2B = 0x00;
TCCR2A = 0x00;
TCCR2B = 0x05; // set divider for one second
TIMSK2 |= (1 << TOIE2); // enable TIMER2_OVF_vect
sei(); // global interrupt enable
while(1) {
//PORTA |= (1 << PinNumber); // this somehow causes the interrupt to "starve"
PORTA |= (1 << PA6); // this works as expected
EDIT: The practical background is, that we observed the ISR not executing correctly when repeatedly changing several output ports, where the pin number is variable at runtime.
