enter image description hereI have a transformer that I've taken out of scrap. I'm trying to discern it's electrical specifications. In my setup I have a function generator hooked up to the primary winding, and an oscilloscope hooked up to the secondary winding.
When I apply a 1V P-P sine wave across the primary winding @ 10Hz, I get 80mV P-P on the secondary winding
When I apply 1V P-P sine wave across the primary winding @ 100Hz, I get 740mV P-P on the secondary winding
When I apply 1V P-P sine wave across the primary winding @ 1KHz, I get 3.6V P-P across the secondary winding
I'm confused because shouldn't the transformer produce an output that's a constant multiple of the input amplitude (Vprimary * turns ratio)? It seems to effectively be acting as a high pass filter. Is this normal or expected behavior? How can I properly measure the turns ratio, a physically-derived, frequency-independent property?
The line impedance of the primary winding is 1 Ohm.
Thanks.
  • The word "transformer" covers a huge range of devices, from tiny RF transformers, through audio coupling transformers and large mains power transformers. Can you give us an idea of what sort of thing you're talking about, perhaps even post a picture? – Dave Tweed Dec 16 '14 at 00:48
  • Thanks for your help. I've added a photo of the transformer. It's about 1 cubic inch. – user2856006 Dec 16 '14 at 00:57
  • Ah. That's an audio coupling transformer, which will have limited performance at low frequencies. The measurements at 1 kHz should be fairly representative. – Dave Tweed Dec 16 '14 at 00:58
  • I'm pretty new to transformers. Apart from just 'googling it' do you have any reference recommendation that I could go to to read up on this stuff a bit more? – user2856006 Dec 16 '14 at 01:03
  • I suspect because it's an audio coupling transformer, it'll be designed to work in the human hearing range, so between 20Hz and 20kHz. What's the reason why the performance is poor at low frequencies? – user2856006 Dec 16 '14 at 01:04
  • Well, it might cover that full range if it came from a piece of high-performance gear, but it looks more like something from a piece of portable equipment. The frequency response will be more along the lines of 200 Hz to 10 kHz at best. If it came from something attached to a phone line, it will be more like 300 Hz to 3 kHz. The minimal amount of metal in the core limits the response at low frequencies. For comparison, a professional-grade audio line coupling transformer will have about 10x the mass. – Dave Tweed Dec 16 '14 at 01:20
    When you connected the input signal to the transformer primary, did you confirm that the input signal was not suddenly attenuated by the transformer? – Andy aka Dec 16 '14 at 08:29
  • Take a look at this discussion http://electronics.stackexchange.com/questions/22254/transfer-function-of-non-ideal-transformer The transfer function of a non ideal transformer influence the response of the secondary side. – R Djorane Dec 16 '14 at 10:21
  • Andy - Yeah, I verified, the input signal wasn't suddenly attenuated by the transformer. – user2856006 Dec 16 '14 at 21:05
Given its size, that is likely to be an audio coupling transformer, rather than an AC mains transformer - assuming its core is separate metal laminations.
(If it has a ferrite core, then it may be designed for high frequency use, in a PSU, but it looks like metal laminations).
Audio coupling transformers usually fall into 2 classes : wide bandwidth for pro audio use (ideally 20Hz to 20kHz) or telephony, usually 300 to 3400Hz. The measurements you have made so far suggest the latter.
The transformer's performance is mainly determined by three quantities (and their interaction with the circuitry around it)
  1. Turns ratio (determines voltage gain)
  2. Primary inductance (determines LF performance)
  3. Leakage inductance (determines HF performance)
It's also worth knowing three more quantities:
  1. Primary resistance (measured at DC, presumably 1 ohm from your question)
  2. Secondary resistance (measured at DC)
  3. Leakage capacitance (can be indirectly determined)
Turns ratio is close to the best voltage ratio you measure, probably 3.6:1.
The ratio of secondary to primary resistances will be approximately the turns ratio squared (not exact, it depends on the nearest wire gauge) so your secondary R is probably about 13 (10 to 16) ohms.
Primary inductance is measured across the primary (duh!) with the secondary open circuit. If you can't measure inductance directly, you can connect a known capacitor in parallel and find the resonant frequency.
Now the primary inductance is effectively in parallel with the load (its purpose is to magnetise the core, generating the flux that communicates signal to the secondary). So it, combined with the source impedance of your signal generator, (actually that source impedance plus the 1 ohm primary resistance) form a series R-L circuit - which is the high pass filter you have observed. (600 ohms is a traditional source impedance in audio work, your signal generator may be different, maybe 50 ohms if it covers radio frequencies)
You can improve the LF performance by driving the transformer from a low source impedance (e.g. an audio power amplifier) reducing R1.
You can't eliminate the primary resistance (R2) for perfect LF performance, but I've seen transformers driven from negative source impedances to partially cancel it. (Not a common trick : as you can probably guess, unstable when the transformer is replaced with a better one!)
Now the leakage inductance is measured in the same way, but with the secondary shorted. Smaller is better; it determines the high frequency performance of the transformer.
simulate this circuit
The leakage inductance forms a series L-R circuit with the load, which is R3 / turns SQUARED. So to get good high frequency response, keep R3 high.
But there is a practical limit on this : the leakage capacitance C1 resonates with leakage inductance, limiting the high frequency response, and providing a frequency response peak. Use this peak to determine the capacitance. It can be controlled (damped) by reducing the value of R3 or a separate Zobel network
  • Thanks so much for this awesome, thorough answer! This makes a lot of sense to me. I measured the secondary resistance to be 93 Ohms, which got me thinking that there still may be another "decade of performance" since the max voltage gain I measured earlier was 3.6 @ 1KHz. When I crank up the V1 frequency to about 10KHz, I get about 9V P-P output with a 1V P-P input, which is roughly sqrt(93 Ohms /1.1 Ohms); so that checks out. My signal generator can go up to 25 MHz, so it has a lower output impedance of 50 Ohms. – user2856006 Dec 16 '14 at 21:03
  • So wouldn't there also be a secondary inductance and a secondary leakage inductance? Where does that factor into our model? – user2856006 Dec 16 '14 at 21:14
  • Then it's probably a pulse transformer, rather than for audio. If it's 10db down at 1kHz fed from 50R, let's say -3dB about 3 kHz, suggests L about 2.5mH. Find a C that would resonate with 2.5mH at a suitable frequency, and see if you can find the actual resonance, and calculate the actual L. –  Dec 16 '14 at 21:19
  • The above circuit is a _model_ of the transformer rather than the reality. So you don't need to consider a "secondary inductance" etc because the secondary isn't magnetising the core. HOWEVER you can use the transformer in reverse. In which case you can model the new primary inductance (ditto leakage) as being the current one scaled by the turns ratio, N^2. –  Dec 16 '14 at 21:22
