I am porting some legacy code from an ARM926 core to CortexA9. This code is baremetal and does not include an OS or standard libraries, all custom. I am having a failure that appears to be related to a race condition that should be prevented by critical sectioning of the code.
I want some feedback on my approach to see if my critical sections may not be correctly implemented for this CPU. I am using GCC. I suspect there is some subtle error.
Also, is there an opensource library that has these types of primitives for ARM (or even a good lightweight spinlock/semephore library)?
#define ARM_INT_KEY_TYPE            unsigned int
#define ARM_INT_LOCK(key_)   \
asm volatile(\
    "mrs %[key], cpsr\n\t"\
    "orr r1, %[key], #0xC0\n\t"\
    "msr cpsr_c, r1\n\t" : [key]"=r"(key_) :: "r1", "cc" );
#define ARM_INT_UNLOCK(key_) asm volatile ("MSR cpsr_c,%0" : : "r" (key_))
The code is used as follows:
/* lock interrupts */
ARM_INT_KEY_TYPE key;
ARM_INT_LOCK(key);
<access registers, shared globals, etc...>
ARM_INT_UNLOCK(key);
The idea of the "key" is to allow nested critical sections, and these are used at the beginning and end of functions to create reentrant functions.
Thanks!
CodePoet
  • 407
0 Answers0
