I ran a simulation for a combinational logic circuit with 8 inputs, 4 outputs inside MODELSIM. When I view the simulated waveform everything looks fine, however when I export result to a list file there are some intermediate valued related to deltas inside a time slot like this:
t(ns) delta               output input
    460  +1                   4'h1 8'h2E
    460  +4                   4'h0 8'h2E
    460  +5                   4'h2 8'h2E
    470  +1                   4'h2 8'h2F
    470  +4                   4'h3 8'h2F
    480  +1                   4'h3 8'h30
    480  +4                   4'h2 8'h30
    480  +5                   4'h4 8'h30
    480  +6                   4'h6 8'h30
    490  +1                   4'h6 8'h31
    500  +1                   4'h6 8'h32
    500  +4                   4'h7 8'h32
    500  +5                   4'h5 8'h32
    510  +1                   4'h5 8'h33
    510  +6                   4'h7 8'h33
    510  +9                   4'h5 8'h33
I want to know what are these intermediate values and will they cause problem for my circuit or not?
e.g. there are 3 value for t=460ns
placeholder
  • 29,982
  • 63
  • 110
VSB
  • 402
A delta is a small (infinitesimal) time increment that is used during simulation. The number listed is the number of these time steps that were taken to resolve the signal timing. You can suppress these with the -NODELTA switch on the command line.
This is telling you that the signal is changing after the main time tick event. To know what value is presented at the next time tick, you take the last delta value. So for the 460 ns value you take the 460 +5 as the value out just prior to the 470 ns time tick.
If you want to know what activity was happening just after 460 ns then you look at the deltas.
placeholder
  • 29,982
  • 63
  • 110
Simulation cycles are characterized by those that result in the advancement of simulation time and those that don't. Those that don't are known as delta cycles.
From a simulation cycle resulting from the advancement of simulation time assignment to a signal without a delay (e.g. after, wait for) will cause a delta cycle as the next simulation cycle without changing the current simulation time. Delta cycles occur until there are no more signal assignments to the current simulation time.
It's how the simulator emulates parallelism. Simulation consists of executing processes in response to events on signals causing processes to wake from sleep. And every concurrent statement is devolved into equivalent processes and/or block statements which represent hierarchy, function calls are expressions.
When there are no events scheduled at the current simulation time, simulation time is advanced to the earliest any event is scheduled in any projected output waveform for any driver (there's a queue).
When there are no scheduled events at a future simulation time, simulation time is advanced to the maximum simulation time and simulation is complete.
This isn't specific to Modelsim, the simulation cycle is defined in the VHDL LRM, and is used for simulating most HDLs. It was originally defined in CONLAN an HDL project that went from 1971 to 1983.
The number of delta cycles executed can be used as feedback to the efficiency of a design model, you can set the maximum number allowed in a simulation.
The information can also be used to construct a graph or waveform showing sequence of model execution across all simulation cycles.
The information is of no particular interest unless you want to understand sequence of assignments in model execution or improve model performance.
If you trace back how the values are generated for those +4, +5 and +9 delta cycle occurrences you'd learn why there are so many.
