18
I want to calculate the cutoff frequency for a specific filter, but I can't find any formula for that.
I know the formula for the cutoff frequency of a low pass filter:
$$f_c=\frac{1}{2\pi RC}$$
But how is that derived in the first place? I don't have a regular low pass filter, but something similar that I want to calculate the cutoff frequency of.
rablentain
  • 421
  • Can you specify the filter by providing a circuit diagram. I can explain the cut off frequency for a simple RC low pass filter and others already have but without knowing what filter you have in mind its difficult to be specific for your case. – Warren Hill Nov 28 '14 at 09:03
    In your question You speak about a "specific filter". Please note that (a) the formula for fc you have given applies to a first order lowpass only and (b) that the -3dB criterion does NOT apply for all kind of filters. Therefore, please tell us how your "specific filter" looks like. – LvW Nov 28 '14 at 08:44
  • stack dsp forum does a lot of filter maths. – bandybabboon Dec 10 '17 at 21:17
  • http://www.analogzoo.com/2015/12/deriving-the-rc-filter-transfer-function/ – 1110101001 Apr 27 '18 at 01:49
The specific formula applies only for a first order RC low pass filter. This is derived from its frequency response:
$$H(j\omega)=\frac{1}{1+j\omega RC}$$
The cutoff frequency is defined as the frequency where the amplitude of \$H(j\omega)\$ is \$1\over\sqrt2\$ times the DC amplitude (approximately -3dB, half power point).
$$|H(j\omega_c)|=\frac{1}{\sqrt{1^2+\omega_c^2R^2C^2}}=\frac{1}{\sqrt{2}}\cdot|H(j0)|=\frac{1}{\sqrt{2}}$$
Solve it for \$\omega_c\$ (cutoff angular frequency), you'll get \$1\over RC\$. Divide that by \$2\pi\$ and you get the cutoff frequency \$f_c\$.
If you know the frequency response of your filter, you can apply this method (given that the cutoff frequency is defined as above). Obviously, for high-pass filters for example, you calculate with the value for \$\omega\to \infty\$ as opposed to the DC value (always the maximum of the amplitude response, relative to which there is a 3dB decrease in amplitude at the cutoff frequency.)
hryghr
  • 1,179
For a simple RC low pass filter, cut-off (3dB point) is defined as when the resistance is the same magnitude as the capacitive reactance: -
\$R = \dfrac{1}{2\pi f C}\$
It's a simple math trick to say: -
\$f = \dfrac{1}{2\pi R C}\$
  • It is not only a pure definition. The main conception of definition cut-off frequency is that the output power becomes half of the input power or equally since `P = V^2 / Z` the amplitude of output voltage becomes square root of 0.5 of input voltage. Then you have a simple voltage divider circuit as `Vout / Vin = Z1 / Z1 + Z2` and can easily find the cut-off frequency by equaling it to square root of 0.5. – Pana Dec 12 '19 at 10:37
  • It's a circular argument, a chicken or egg situation. I regard both as equally valid. – Andy aka Dec 12 '19 at 10:41
  • Yes, right. But please pay attention that OP needs to know the concept of obtaining cut-off frequency to be able to calculate the cut-off frequency of their own filter: `I don't have a regular low pass filter, but something similar that I want to calculate the cutoff frequency` – Pana Dec 12 '19 at 10:45
  • I believe I have answered the OP's questions and he/she has accepted a different answer (back in 2014) i.e. 5 years ago. – Andy aka Dec 12 '19 at 10:50
