I'm trying to connect a ENC28J60 module that exposes a SPI interface to my Beaglebone Black. I only have pins 1 (NET_CS), 2 (SCK), 3 (MOSI, i.e., D0), 4 (MISO, i.e., D1), 5 (GND), 10 (VCC) connected to my Beaglebone's SPI1 interface. The pins that I have connected are as follows. The pins that I don't have connected are labeled N/A
in the BBB PIN
column.
ENC PIN | FUNCTION | BBB PIN
1 | NET_CS | P9.28
2 | SCK | P9.31
3 | MOSI | P9.29
4 | MISO | P9.30
5 | GND | P9.03
6 | WOL | <N/A>
7 | NET_INT | <N/A>
8 | CLKOUT | <N/A>
9 | NET_RST | <N/A>
10 | VCC | P9.01
I've used the following device tree overlay to configure my pins.
/dts-v1/;
/plugin/;
compatible = "ti,beaglebone", "ti,beaglebone-black";
/* identification */
part-number = "BB-ENC28J60";
/* version */
version = "00A0";
/* state the resources this cape uses */
exclusive-use =
/* the pin header uses */
"P9.24",
"P9.25",
"P9.26",
"P9.27",
"P9.28",
"P9.29",
"P9.30",
"P9.31",
"spi1";
fragment@0 {
target = <&am33xx_pinmux>;
__overlay__ {
pinctrl_spi1: pinctrl_spi1_pins {
pinctrl-single,pins = <
0x184 0x37 /* P9_24 RST | IN_PULLUP | MODE7 */
0x1ac 0x37 /* P9_25 INT | IN_PULLUP | MODE7 */
0x180 0x37 /* P9_26 WOL | IN_PULLUP | MODE7 */
0x1a4 0x37 /* P9_27 CLKOUT | IN_PULLUP | MODE7 */
0x19c 0x13 /* P9_28 SPI1_CS | OUTPUT_PULLUP | MODE3 */
0x194 0x33 /* P9_29 SPI1_D0 | INPUT_PULLUP | MODE3 */
0x198 0x13 /* P9_30 SPI1_D1 | OUTPUT_PULLUP | MODE3 */
0x190 0x3B /* P9_31 SPI1_SCLK | INPUT_PULLUP | MODE3 */
fragment@1 {
target = <&spi1>;
__overlay__ {
#address-cells = <1>;
#size-cells = <0>;
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_spi1>;
spidev@0{
compatible = "microchip,enc28j60";
reg = <0>;
interrupt-parent = <&gpio3>;
interrupts = <21>;
spi-max-frequency = <20000000>;
spidev@1{
compatible = "spidev";
reg = <1>;
spi-max-frequency = <24000000>;
Note, for other readers, I have no idea what I'm doing with this device tree, especially with regards to the interrupt
I chose in this example. So don't cut and paste it.
Having only these pins connected seems to be sufficient for identifying the module as a networking interface from a Debian running on my Beaglebone. I checked the dmesg
log after the cape was applied and saw the following. When I play around with the wiring by reversing MISO and MOSI or some other combination involving CS or CLK, I consistently get errors in dmesg
. That makes me think I'm on the right track, or at least that my wiring is correct.
[ 57.074485] bone-capemgr bone_capemgr.9: part_number 'BB-ENC28J60', version 'N/A'
[ 57.074670] bone-capemgr bone_capemgr.9: slot #7: generic override
[ 57.074721] bone-capemgr bone_capemgr.9: bone: Using override eeprom data at slot 7
[ 57.074774] bone-capemgr bone_capemgr.9: slot #7: 'Override Board Name,00A0,Override Manuf,BB-ENC28J60'
[ 57.075043] bone-capemgr bone_capemgr.9: slot #7: Requesting part number/version based 'BB-ENC28J60-00A0.dtbo
[ 57.075098] bone-capemgr bone_capemgr.9: slot #7: Requesting firmware 'BB-ENC28J60-00A0.dtbo' for board-name 'Override Board Name', version '00A0'
[ 57.086968] bone-capemgr bone_capemgr.9: slot #7: dtbo 'BB-ENC28J60-00A0.dtbo' loaded; converting to live tree
[ 57.088829] bone-capemgr bone_capemgr.9: slot #7: #2 overlays
[ 57.140361] edma-dma-engine edma-dma-engine.0: allocated channel for 0:45
[ 57.140553] edma-dma-engine edma-dma-engine.0: allocated channel for 0:44
[ 57.222844] edma-dma-engine edma-dma-engine.0: allocated channel for 0:43
[ 57.223015] edma-dma-engine edma-dma-engine.0: allocated channel for 0:42
[ 57.223509] enc28j60 spi1.0: enc28j60 Ethernet driver 1.01 loaded
[ 57.237571] net eth1: enc28j60 driver registered
[ 57.247437] bone-capemgr bone_capemgr.9: slot #7: Applied #2 overlays.
If I crank up the debugging level on the interface and ifconfig up
the new interface I see the output below in my kernel log.
Nov 24 08:58:53 arm kernel: [ 117.451971] enc28j60: enc28j60_net_open() enter
Nov 24 08:58:53 arm kernel: [ 117.456764] enc28j60: enc28j60_hw_init() - HalfDuplex
Nov 24 08:58:53 arm kernel: [ 117.456813] enc28j60: enc28j60_soft_reset() enter
Nov 24 08:58:53 arm kernel: [ 117.461525] enc28j60: chip RevID: 0x06
Nov 24 08:58:53 arm kernel: [ 117.469000] enc28j60 Hw initialized.
Nov 24 08:58:53 arm kernel: [ 117.469000] HwRevID: 0x06
Nov 24 08:58:53 arm kernel: [ 117.469000] Cntrl: ECON1 ECON2 ESTAT EIR EIE
Nov 24 08:58:53 arm kernel: [ 117.469000] 0x03 0x88 0x01 0x00 0x00
Nov 24 08:58:53 arm kernel: [ 117.469000] MAC : MACON1 MACON3 MACON4
Nov 24 08:58:53 arm kernel: [ 117.469000] 0x0d 0x32 0x40
Nov 24 08:58:53 arm kernel: [ 117.469000] Rx : ERXST ERXND ERXWRPT ERXRDPT ERXFCON EPKTCNT MAMXFL
Nov 24 08:58:53 arm kernel: [ 117.469000] 0x0000 0x19ff 0x0000 0x19ff 0xa1 0x00 0x05ee
Nov 24 08:58:53 arm kernel: [ 117.469000] Tx : ETXST ETXND MACLCON1 MACLCON2 MAPHSUP
Nov 24 08:58:53 arm kernel: [ 117.469000] 0x1a00 0x1fff 0x0f 0x37 0x10
Nov 24 08:58:53 arm kernel: [ 117.469118] enc28j60: eth1: Setting MAC address to 62:78:04:14:a4:b6
Nov 24 08:58:53 arm kernel: [ 117.469602] enc28j60: enc28j60_hw_enable() enabling interrupts.
Nov 24 08:58:53 arm kernel: [ 117.472893] enc28j60: enc28j60_check_link_status() PHSTAT1: 1800, PHSTAT2: 0000
Nov 24 08:58:53 arm kernel: [ 117.472942] net eth1: link down
Nov 24 08:58:53 arm kernel: [ 117.472982] net eth1: normal mode
Nov 24 08:58:53 arm kernel: [ 117.473035] net eth1: normal mode
Nov 24 08:58:53 arm kernel: [ 117.473208] net eth1: multicast mode
Nov 24 08:58:53 arm kernel: [ 117.473295] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Nov 24 08:58:53 arm kernel: [ 117.473376] enc28j60: multicast mode
At this point, I'm stuck. My question is if all pins of my module required, or just the SPI-centric ones? If not, any pointers on debugging this further?
