I know nothing about electronics... I need help to figure out if I can use a power adapter that I have on hand for my overseas trip.
I have a Model PA-130 transformer for my Yamaha mixer. It's rated
AC input 110v 60Hz AC Output 12v 1.0A
I am going to Australia. Will I destroy my mixer in a cloud of fire and smoke if I use the following transformer?
Model WA 24c12N AC input 100-240Vac 50-60Hz DC output 12v 2A
If this is not going to work where would I go to purchase a transformer that will work in Australia? I'm in Nashville.
  • possible duplicate of [Choosing power supply, how to get the voltage and current ratings?](http://electronics.stackexchange.com/questions/34745/choosing-power-supply-how-to-get-the-voltage-and-current-ratings) – placeholder Nov 20 '14 at 22:58
The potential replacement is a DC output at 12V. The original is an AC output at 12V. That could be a big difference but it's unlikely to destroy your mixer but it may not work on the DC supply or it may work with distortion on the audio signals.
Reason: An AC output of 12V has a peak voltage that is 1.414 times higher at about 17 V peak. The yamaha mixer will likely rectify that AC voltage to produce a DC level more or less based on the peak voltage of 17 V DC. If you then fed 12V DC into the mixer you are not supplying enough voltage and you may hit problems.
The best place to purchase a power supply that works is Australia. Getting 12V AC from whatever the aussie voltage is will be commonplace.
It looks okay to me, provided you verify the polarity. The PA-130 appears to be a very similar 12VDC SMPS adapter, but limited to 120V in.
Don't forget to verify the polarity- most adapters these days have the center pin positive, but there are exceptions. This Amazon.uk seller claims their adapter is PA-130 compatible, and it's positive center, but the images are too blurry to tell on the Yamaha website.
I would be more confident if your WA 24c12N is an actual Seagate supply and not some dubious thing. There is some awful garbage being sold online these days- dangerous too. You can try it on 120V before you go, of course.
Spehro Pefhany
  • 376,485
  • 842
