When I run 24VAC into a full wave bridge rectifier followed by a 220uF electrolytic capacitor to turn it into ~32VDC, the source has two wires. Does it matter in what order I connect the AC wires to the input to the bridge rectifier? If so how do I determine which wire goes where? I suspect that it's totally symmetric on the input side, but I'm am full of doubt when it comes to AC. Sorry if this is just a really dumb question.
7In some power systems neutral is grounded so yes AC power sometimes can have "polarity" though probably doesn't apply in your case. – Sridhar Nov 04 '14 at 03:58
2@sridhara ... you are correct! but where neutral is grounded, a bridge rectifier probably won't do much good, because the resulting DC supply isn't isolated so you can't connect -V to ground. – Nov 04 '14 at 11:39
When you're looking at an AC source in isolation such as in your question, indeed there's no polarity and you can connect the wires either way round.
When combining two or more AC sources in series or parallel, the relative phasing is very important.
- 6,164
- 20
- 34
3While not relevant in this case, I guess it is worth mentioning that transformers have polarity between the primary and secondary. In schematic symbols, this is denoted by a dot. When the primary terminal with a dot on it goes high, the secondary with a dot on it also goes high. Sometimes this matters. – user57037 Nov 06 '14 at 06:03
As long as you are dealing with a closed system (like a transformer secondary winding + bridge rectifier) then no, AC is not polarized.
However, when dealing with outside power (like what comes out of the wall) we do consider AC-carrying cables to be "polarized". There's the hot wire carrying the juice and the neutral wire carrying the return. The hot wire should go directly to your device's switch / fuse, and any semi-exposed contacts must have the hot wire as protected as possible. If you don't do this on production items you will fail UL certification and be wide open for lawsuits. The common light bulb would likely fail many of today's standards, but it's been around too long to recall.
Devices that don't have a polarized wall plug will use a double-pole power switch to prevent the circuit being live up to the switch.
- 2,083
- 14
- 7
1Among others, the Schuko wall plug (used in most of Europe) is not polarized, so any device intended for those markets will have to assume that both wires are "hot". More: http://electronics.stackexchange.com/questions/96033/symmetric-power-sockets-design-considerations-in-electrical-devices – ntoskrnl Nov 04 '14 at 22:13
1@ntoskrnl Actually all the Schuko plugs I have ever come across were polarized because they were designed to fit in both the Schuko outlets as well as French outlets. But that doesn't help when it is used in a Schuko outlet which is not polarized. – kasperd Nov 05 '14 at 00:10
2@kasperd The polarization of the French type "polarized" plug is not standardized; for example the polarization is reverse in the Czech Republic compared to France. – ntoskrnl Nov 05 '14 at 15:12
@ntoskrnl As the saying goes. Standards are great let's have some more of them. – kasperd Nov 05 '14 at 18:24
@ntoskrnl Here in Poland [“symmetric” dual outlets](http://www.ceneo.pl/1723353) are common where one socket has polarity reversed from the other! – kinokijuf Jan 21 '15 at 21:22
AC voltage has no polarity. Therefore it does not matter how you connect the wires to the bridge rectifier. Also, there are no dumb questions. Feel free to ask about whatever is bothering you. You will learn, as will others, and you will be safer for it.
- 15,733
- 1
- 26
- 28
At the atomic level, with the AC coming out of your transformer there is a herd of electrons which all run one way, then stop, turn round and run the other way half a cycle later. Since the electrons are running in both directions the transformer output has no polarity. The job of the rectifier is to round them up and make them all run in the same direction. Now you know which way they're going they now have polarity. That's why the input of the rectifier doesn't specify which way round to connect the wires, but the output does.
- 11
- 2
For your AC/DC application, the polarity won't make a difference in how it functions, but it's important to understand, in case we're generalizing, that POLARITY MATTERS in hot/neutral circuits in the U.S. [and some other countries] WHY? Because most lamps and other devices with on/off switches are only opening/closing the contacts connecting the HOT wire, and are leaving the NEUTRAL WIRE connected the whole time, so if HOT/NEUTRAL get reversed in the wall outlet, then the lamp's switch is switching on/off the NEUTRAL (instead of the HOT), which means that the light bulb terminal is STILL HOT! when you turn off the light to change the bulb, and you can get the shock of your life if you touch it, and your body happens to be able to complete the circuit to ground. SO, PLEASE make sure your wall outlets are wired correctly.
