CPI compares an immediate value with the accumulator, by internally using a subtract operation:
In particular, the zero bit is set if the quantities are equal, and reset if they are unequal.
Since a subtract operation is performed, the Carry bit will be set if there is no carry out of bit 7, indicating the immediate data is greater than the contents of the accumulator, and reset otherwise.
(Some notes on usage here: I am using I for the Immediate value, and A for the Accumulator).
- First comparison: (A < 0) -> ERR
So you are looking for the carry bit to be 1 (I > A) for the first ERR branch. That can be achieved with JC (Jump if Carry).
- Second comparison: (A > 9) -> ERR
The second CPI wants to see if I < A, which using the same method as above makes things a little tricky. You need to know that the Carry bit is not set (I <= A) and the Zero bit is not set, which gets a little tricky.
JNC performs a Jump if Not Carry, and JZ performs a Jump if Zero. So you want to combine those.
Firstly you know that the Zero bit must not be set under any circumstances. That bit being set would indicate the two values are the same, which is valid. So you can first check that bit to rule it out. Z being set means its a valid entry ('9') regardless of the state of the carry:
JZ GOOD
And then if the Carry bit is not set you can do a JNC to your error routine:
JNC ERR
And finally give it somewhere for the GOOD label t jump to:
GOOD:
So to wrap it all up:
CPI '0' ; Compare with '0'
JC ERR ; Jump to ERR if Acc < '0'
CPI '9' ; Compare with '9'
JZ GOOD ; Jump to GOOD if Acc == '9'
JNC ERR ; Jump to ERR if Acc > '9'
GOOD: NOP ; This is where we end up if it's all valid.
So remember, when doing a CPI you can test for the three things - exactly equal to (Z = 1), Less than (C = 1), and Greater Than or Equal To (C = 0).
If you want to lose some readability, but save a byte or two of program space, you can instead of comparing your upper bound with '9', compare it with '9'+1, which is ':'. That way you're only really interested in the "less than" portion of the CPI, and all others go to ERR:
CPI ':' ; Compare with '9'+1 = ':'
JNC ERR ; Jump to ERR if Acc >= ':'
