Safety
Will the battery or charger be damaged if I use a 1A charger to charge a 2.1A appliance?
Will the battery or charger be damaged if I use a 2.1A charger to charge a 1A appliance?
Duration
I have tried both of the above. What I notice is that when I use the 1A charger to charge the 2.1A appliance, the charging time is extremely long. I understand that because Q = It, a smaller current would take longer to deliver the same amount of charges.
Conversely, when I use the 2.1A charger to charge the 1A appliance, should I expect the charging time to be shorter, or the same as if I used a 1A charger?
