I am a beginner, I am confused about calculating the nessecary gain and power and sensitvity to overcome path loss at certain distances.
the first thing what does gain mean ? I am not talkink about identification , but how to use this term ?
let say we have 100 watt "50 dBm" transmitter connected to an amplifier has 70 dB gain and output power of 400 watt "56 dBm" connected to antenna has a gain of 15 dBi .
simply how to calculate the total budget ? is just adding gain to last output power to antenna gain right ?
or we just adding the total gain of amplifier and antenna and ignoring power ?
should I adding receiver antenna gain & sensitivity also ?
man abduo
  • 59
  • if we add for example 50 db amplifier to receiver , should be adding this gain to calculation of total budget ? "ignoring the noise " – man abduo Oct 20 '14 at 19:54
Gain is the power amplification of a system usually expressed in decibels.
Link budget, as the name implies is the power budget from one end of the link to the other and should take account of: -
  1. Tx amplifier power lost in feeder to antenna
  2. VSWR effects due to mismatched coax/amp/antenna
  3. Antenna losses (especially if not bang on the optimum frequency)
  4. Antenna gain (aka directivity) - usually a minimum of 1.7dB per antenna
  5. Localized losses in antenna structure (usually low by design)
  6. The actual free-space transmission loss of power versus frequency and distance
  7. The extra losses due to fade and the fact the earth isn't free-space
  8. The receive antenna gain
  9. Rx mismatches and feeder losses to receiver
Lastly, you should understand that if transmitting anything you are occupying a finite bandwidth in the spectrum and that bandwidth comes with a cost - noise. Let's begin with this. The minimum power in dBm that a receiver needs to generally operate with a low bit error rate is: -
dBm = -154dBm + \$10\space log_{10}(data\space rate)\$
So if you are transmitting 1Mbps the minimal signal you'll need at your receiver input terminals is -154dBm + 60 dBm = -94 dBm.
This accounts for your receiver being at normal ambient temperatures of 300k.
Assuming you can put figures on cable losses and antenna gains and that mismatches are minimized the basic free space link loss equation is: -
Link Loss (dB) = 32.4 + 20\$log_{10}\$(F) + 20\$log_{10}\$(d) where F is in MHz and d is kilometres
This tells you how many dB are lost at a particular frequency over a certain distance in free-space (not earth). Usually, RF guys then assume it's going to be at least 20dB worse than that (margin for fading) and that in a highly populated area it will be possibly 20dB worse again.
It all sounds a little haphazard but with care and attention to detail these equations produce very realizable systems.
I'm not going to comment on your figures because
.... makes no sense to me. I don't understand what you are trying to say.
See also other answers on this Long range (~15 km) low baud-rate wireless communication in a mountain environment (no LOS) and How to know (or estimate) the range of a transceiver?
  • I talking about a system has a gain of 70 db and power of 50 dbm connected to 15 dbi antenna "just example" if I want to calculate total budget, can I say the budget = 70 "system gain" + 50 "system power" + 15 "antenna gain" ? – man abduo Oct 20 '14 at 20:04
  • A 50dBm power connected to a 15dBi gain antenna pumps out 50dBm but the energy is concentrated in one direction therefore it looks like a power output of 65dBm transmitted by an omni-directional antenna (aka isotropic antenna). The "i" in isotropic is the same "i" used in the term "dBi" The 15dBi antenna has "gain" compared to the theoretical (and non-existant) isotropic antenna. – Andy aka Oct 20 '14 at 20:08
  • there is another 70 db gain from amplifier , should we add it to the 65 dBm ? that is my qustion – man abduo Oct 20 '14 at 20:11
  • Sure, 50dBm becomes 120dBm but that is 1 billion watts - maybe you have an error somewhere? This is why I couldn't comment on that part of your question. – Andy aka Oct 20 '14 at 20:13
  • I talking about something like that http://www.everythingrf.com/products/microwave-rf-amplifiers/rohde-schwarz/567-92-r-s-bba100-series has a gain of 65 db and power of 70 dbm !! – man abduo Oct 20 '14 at 20:19
  • It has a power out of 70dBm but the gain isn't added on top - the gain tells you it will produce 70dBm with an input level of 5dBm i.e. 70dBm minus 65dB. – Andy aka Oct 20 '14 at 20:32
  • so should I add the gain to calculation and ignoring power ? or add power and ignoring gain from amplifier ? what about cellular repeaters and antenna amplifiers ? – man abduo Oct 20 '14 at 20:37
  • The gain just tells you how small the input to the "box" can be. Regards link-loss you use the output power from the amplifier/box, Cell repeaters are well beyond the scope of this question - deal with the basics first. Antenna amps add dBs to the output power transmitted or input power received. – Andy aka Oct 20 '14 at 20:41
  • if I add low power high gain amplifier to a receiver for example with 50 db , with ignoring noise amplification that it mean the receiver sensitivity increasing fromm -90 dBm to -140 dBm "example" ? – man abduo Oct 20 '14 at 20:42
  • to my understand that is mean antenna amplifier amplify only the output from Tx , but should not exceed certain power, right ? – man abduo Oct 20 '14 at 20:48
  • No - adding a receive amp does not improve things - it will amplify in-band noise and signal identically - you get a bigger signal with bigger noise. Tx Antenna amps are very rare because it's cheaper to send more power down the feeder from (say) within a building than add an amp to a vulnerable position on an antenna. Also tx amps can be quite unstable due to the antenna feeding the input to the amp and you get an oscillator. I think you need to consider asking new questions formally because this is getting beyond the scope of what was originally asked and you'll get others offering advise. – Andy aka Oct 20 '14 at 21:13
