-3
When I connect my headphone to headphone jack in my laptop, I don't hear any sound. Unless I do not fully plug it in and instead just plug it in around 50%.
Sometimes I hear sound but it is all garbled.
This headphone used to work fine before and now it is giving me this problem for some time.
If I connect another headphone then it works fine so I don't think headphone jack is the problem.
Does anybody know why this is happening and how to fix it?
EDIT
Found a similar question. When I said that sometimes I head sound but it is all garbled then this is what I was talking about as discussed in this question.
Why do speakers sound different when they're not fully plugged in?
Frank Martin
    This is probably off topic, but have you tried different headphone/device combinations? – clabacchio Oct 14 '14 at 13:21
    If another pair of headphones work fine it sounds like the headphones are the problem. Probably a loose or intermittent connection. – ACD Oct 14 '14 at 13:21
  • Related: [What is it that strips vocals from audio when a 1/8" audio jack is partially unplugged?](http://electronics.stackexchange.com/q/42623/2028) – JYelton Oct 14 '14 at 18:14
Probably one of the wires coming out of the plug has broken. Cut off the plug along with a few inches of cable (to get past the point where a wire is broken), then solder on a new plug.
Olin Lathrop
  • 310,974
  • 428
  • 915
