I am attempting to control speaker volume via a digital potentiometer, the problem being that audio signal goes both above and below 0V, for regular potentiometers this is no problem but for digital they cannot handle a signal below ground.
How can I shift the signal up to always be above 0V? I believe this is called biasing, so instead of -2V to 2V it'll be 0V to 4V. I have seen example circuits for this. So for me the more important question is do I have to shift it back down for the speakers to "understand" the signal again?
JYelton
  • 32,302
  • 134
  • 249
Smanger
You can shift it like this if you don't have the center voltage already available:
Or like this if you do:
simulate this circuit
You may recognize it as a highpass filter, which it is. In signal processing, DC (constant offset) is 0Hz, and is considered a frequency just like any other. Set the cutoff frequency well below the lowest point of interest.
As for the speakers, yes, you should offset it back, using the speakers' ground as the center point. You should probably add a buffer amp between the pot and the output, which you can take advantage of as an active highpass filter. This circuit takes that idea one step further by coaxing a linear pot into a somewhat decent log response, which is a little bit better suited for the way we naturally measure volume:
It may not be immediately obvious, but I used one of each variation. The input one is almost obvious - I'm using the digipot itself as R2 - and the other can be seen by realizing that the (-) input of the opamp is actively held at the speaker ground, which is the desired center point. Also, by loading the pot with R3 to ground, I can convert a linear response into a semi-log one.
The classic inverting opamp then takes the voltage that appears between C2 and R3 and puts it on the output with a gain of (-R4/R3). This means that you can make R4 variable in order to match the digipot's volume range with the speakers' volume range, which is generally a good idea in my opinion. Once set, it should never be moved again unless you change your setup, so it doesn't need to be anything fancy.
Two things to note:
  1. The opamp needs a wide enough power supply to cover the entire +/- voltage range that the speaker can handle, or that you care to give it. It can't go outside of its own supply.
  2. Power on/off transients typically go straight through this kind of filter because they're relatively high in frequency content. At this point in time, the cap is charged incorrectly for the required offset and so you might need some kind of over/undervoltage protection between C1 and the digipot and between C2 and the opamp. You can use a pair of zener diodes in reverse series from the signal to the center point if you have it and it's "stiff" enough compared to the supply rails, or you can use a shottkey diode from the signal to each supply rail of the device that it's about to go into.
AaronD
  • 5,596
  • This is an awesome answer, i'm still trying to wrap my head around it so i'll post some questions. I'm not so sure how to choose the ? values you provide? When you say v+ or v- are you meaning the range i want to move it into? Because the tricky part is, i have no idea what the actual headphone voltage range is.. I've read articles but they are all below 2v, which i assume means between -2v and 2v. – Smanger Oct 14 '14 at 05:10
  • Start with the digipot. It probably has a set value already, so you can fill that in. Then choose R1 so that the center point naturally floats at the center point that you want. Then choose C1 given R1||R2 (yes, parallel) to give an RC cutoff frequency that is much less than the lowest bass you want to pass. Add some clamping diodes as in note 2 of my answer, and the first stage is done. – AaronD Oct 14 '14 at 14:40
  • Choose R3 to be roughly 1/5 to 1/10 of R2 (digipot) for a decent log response (from http://sound.westhost.com, project01). Then choose C2 for a similar cutoff frequency that you have in the first stage. Then choose R4 to set the output gain, add the clamping diodes again, and the second stage is done. – AaronD Oct 14 '14 at 14:45
  • For audio signals, there really isn't a set max or min except for the power supplies or excursion limits of the various equipment that it goes through. (one notable exception is 70V distribution to many speakers via individual transformers, but you're not doing that) Higher is louder, but also keep in mind that some headphones/speakers are more sensitive than others. You should set each intermediate volume control so that the entire chain clips at about the same level, then turn things down from there, starting at the end. That gives you the volume you want with minimal noise. – AaronD Oct 14 '14 at 15:02
  • OK So with the digipot being 10k when you say "the center point naturally floats at the center point that you want". The goal being centerin on 2.5v, i adjust R1 to give this but won't this center point change when the resistance in the digipot changes? – Smanger Oct 14 '14 at 19:27
  • Nope. When looking at DC, you treat all capacitors as open circuits, so in that case the position of the wiper does nothing and you're left with just a voltage divider. You may get a brief error when you change settings, but it'll settle out pretty quick. Another reason to be careful about changes is to avoid the zipper sound that comes from stepping quickly through discrete settings. Whether or not that's noticeable depends on when, how often, and how much you change it. – AaronD Oct 14 '14 at 19:42
  • Ok, starting to come together now, thanks again you've been super helpful. To your first point about the op amps supply range. Assuming -1.2v to 1.2v which gets shifted up to center on 2.5v, is it ok to have the op-amp supplied with 5v - 0v as that covers the whole input range? Or do i need to supply it with like 2v and -2v since the output is below ground? – Smanger Oct 14 '14 at 20:00
  • C2 will handle whatever offset comes from the digipot, so you don't need to worry about that. The opamp's supply should be concerned with the output to the speaker. Also note that most low-distortion opamps won't go all the way to their supply rails; they'll clip a volt or two short. Make sure you account for that also. Most people seem to have standardized on +/-15V to power analog circutry - 30V total with a center tap connected to the speaker ground - but you may not need that much. Wouldn't hurt though, if your speaker can handle it. – AaronD Oct 14 '14 at 20:23
  • Well this isnt going directly to the speaker. The way it's set up now is a headphone jack going to a dual 10k pot. I'm just trying to put this digipot in the place of it, but it needs positive voltage since the digi can't take anything below 0v.. Sounds like i need a -3 or -5 voltage for the op amp then to get back to the output range of -2 to 2v range. – Smanger Oct 14 '14 at 20:33
  • Sounds to me like you'd be okay with using the digipot's positive supply and a matching negative supply that can be derived from the positive one. You can start another question about that. – AaronD Oct 14 '14 at 20:54
  • Thanks, this is by far the best answer I've ever had from stack exchange. – Smanger Oct 15 '14 at 00:06
You should. Adding the DC offset will shift the speaker's diaphragm in one direction, limiting the travel of the diaphragm in that direction. In addition, the constant current flow will cause much more heat dissipation, especially at higher volumes.
This link has a decent explanation of this.
