I want to control a brushed DC motor of the below specification:
  • Motor: Permanent magnet DC brushed motor
  • Voltage: 180V
  • Current: 5 Amps
  • RPM: 1500
The control method is PWM switching through a microcontroller, with speed as a feedback.
This is the basic control block diagram:
How to select the MOSFET for controlling the above motor?
What should be the MOSFET continuous current Id, Drain-Source VDS, RDS, VGS (for the given motor rating)?
Switching Frequency 10 KHz
MOSFET Package: Through hole will be apt
Based on the ratings I have designed the circuit below is the same with component specification:
The control circuit is working fine, except I have encountered once MOSFET failure, that is why I was wondering if I have to increase the MOSFET rating.
Mosfet Details:
  • IRFP460
  • VDS = 500V
  • RDS = 0.27ohm
  • Id = 20 A (at 25°C)
And I have put considerable heat sink to dissipate heat from the MOSFET.
So I thought if there is a standard way of choosing the MOSFET, then I could compare with the one I have already chosen.
JYelton
  • 32,302
  • 134
  • 249
siva
  • 99
  • do you want surface mount or through-hole package? What switching frequency will you be using? – KyranF Oct 09 '14 at 12:35
  • @KyranF I have updated the frequency and package. – siva Oct 09 '14 at 12:40
  • I have provided an answer, with some of my thoughts – KyranF Oct 09 '14 at 12:47
  • Measure the DC resistance of the motor - several times, turning the shaft between measurements, and post the lowest measurement. If it's 3 ohms, that suggests 60A starting current, or with the motor stalled... –  Oct 09 '14 at 12:54
  • @BrianDrummond Sure I will measure and update the same, but how are you saying the starting current will be 60A . – siva Oct 09 '14 at 13:24
  • 180V/3 ohms. In practice it will be lower thanks to power supply limitations, and you can keep it lower still, using PWM to soft start it (i.e. keep the PWM duty cycle low until the motor is running). But the possibility for such high starting currents - or fault currents - is there, and the design cannot ignore them. –  Oct 09 '14 at 13:37
I would go for 1.5x voltage rating just to be safe, meaning 270-300V. Most of the N Channel FETs I see on Digikey with those specs, and are cheap/plentiful, are already more than enough in terms of current handling capability.
One of your regular looking TO-220 package FETs such as the FDP14N30 from Fairchild Semiconductor, which is a 300V 14A rated N Channel MOSFET, is plenty enough. It will dissipate 7.5 Watts with 300mOhm On resistance and 5 Amps continuous. It can do pulsed currents up to 56 Amps so i'm sure it will handle start-up current surges. Here is the datasheet from the manufacturer
Basically, try to select a component which is rated at MORE than your given parameters, with reasonable and logical room for less than ideal conditions, such as after temperature has increased or if the component happens to be on the low end of tolerance during manufacture.
If you over-rate components too much though it can cost quite a lot more in terms of production cost and PCB space, but if you have a project for university for example, over-rating a component just means your project will fail less during the desperate times you are trying to do final tests and write your reports etc.
If you expect your motor will be turned without powering it, look out for generated voltages that may actually exceed your 300V rated FET. I suggest you get some heavy duty (300-400V) rated diodes to clamp the motor + and - connections to VCC and GND. This is for "Back EMF" protection, and sometimes the diodes are referred to as flyback or freewheeling diodes I believe (this may help you research the topic, and their use). You can also put a big blocking diode parallel over the + and - connection to the motor, which helps with/does the same thing. These are usually used for any type of inductive load.
Also double check the voltage that your N channel low side gate driver uses, the IC I suggested that you use has +-30V gate voltage ratings, so you should be okay - but there ARE components which have much lower (12V, or 20V) gate voltage max ratings.
Because you will be using a proper gate driver IC, I suspect you will not have problems with 10kHz switching, but when not using a gate driver you may have gate capacitance issues causing higher switching loss, as the MOSFET takes more current to discharge/charge than for example a small micrcontroller output pin can provide. The MOSFET would then be in the "linear resistance" region much longer than if a proper gate driver had been used.
KyranF
  • 6,248
    You can also put FETs in parallel for more throughput, but be aware that this also parallels the gate capacitors, making it even harder to turn them on quickly. – KyranF Oct 09 '14 at 12:55
    If you wanted to go for a higher current handling FET you can go for that FDP's big brother, the FDP24N40 or similar, which is 400V 24A rated, with the same package. – KyranF Oct 09 '14 at 12:58
  • I have already designed the circuit based on the ratings, and its running okay. – siva Oct 09 '14 at 13:00
  • @siva It only takes one microsecond of things not being okay, to blow up ;) – KyranF Oct 09 '14 at 13:00
  • for example if you chose a 200V 6A MOSFET, you will very quickly have a broken device. – KyranF Oct 09 '14 at 13:01
  • I have further updated with the circuit diagram, with additional notes, have a look. – siva Oct 09 '14 at 13:14
  • @siva it seems your mosfet is good enough, do you know what was happening during the MOSFET failure? And did your first FET get very hot? what duty cycle % does your controller output usually, when you reach the desired speed? – KyranF Oct 09 '14 at 13:33
  • During the failure the Mosfet DRAIN and SOURCE pin gets short.Yes ofcourse it get hot, which is why I have put a heavy sink and I have measured the heatsink temperature which is 70.c (max).The duty cycle goes upto maxium of 75%. – siva Oct 09 '14 at 13:43
  • @siva perhaps that was the over-voltage transient, that can cause FETs to fail into short circuits. Try diode clamps. – KyranF Oct 09 '14 at 13:47
  • @siva see this question and it's answer on this site: http://electronics.stackexchange.com/questions/63568/what-can-cause-a-drain-source-short-in-a-fet – KyranF Oct 09 '14 at 13:52
  • Yes, I saw that post, I probably should increase the mosfet ratings since the measured mosfet junction temp is 80.c which will further derate the Max Id allowed(can be seen inthe datasheet) and also I noticed the failure of mosfet happened only when there is sudden increase in load and increase in load will lead to sudden increase in current and then mosfet failure. – siva Oct 09 '14 at 14:09
  • But my doubt is in what factor should I increase these ratings. – siva Oct 09 '14 at 14:10
  • @siva for your next attempt, I say use two in parallel with each their own heat sinks, and try to put a heavy duty 200+V, ~3-10A rated flyback diode across the motor terminals. – KyranF Oct 09 '14 at 14:11
  • it is not really the best thing to just keep up-rating the device. Remember, these things can handle 4-5x the current for short durations (pulse current ratings) such as a load change, and the motor is an inductor itself which naturally limits current surges.. – KyranF Oct 09 '14 at 14:13
