I have capacitors of 100uF, 10uF and 1uF; and need a series circuit with these capacitors to form a 0.1uF capacitor, is this possible?
JYelton
  • 32,302
  • 134
  • 249
Tarantula
  • 423
Capacitors associations
Series association
This association gives a lower total capacity than any of its component capacitors. The total capacity, for \$n\$ capacitors is
$$ C_{eq} = \dfrac{1}{\sum\limits_{n}\dfrac{1}{C_n}} $$
Parallel association
This association gives a greater total capacity than any of its component capacitors. The total capacity, for \$n\$ capacitors is
$$ C_{eq} = \sum\limits_nC_n $$
So, for your question, the answer is yes. You must connect 10 capacitors of 1\$\mu\$F in series.
Martin Petrei
  • 3,034
The equivalent capacitance \$C_{eq}\$ of \$n\$ capacitors \$C_{1}\$, \$C_{2}\$, \$\ldots C_{n}\$ in series is
$$\frac{1}{C_{eq}} = \sum_{i = 1}^{n}\frac{1}{C_{i}}$$
In your case you can connect 10 \$1\mu\$F capacitors in series for an equivalent capacitance of \$0.1\mu\$F.
Null
  • 7,448
