What might be the reasoning for European connectors having rounded prongs while USA and UK connectors are primarily flat pronged?
Please correct any mis-tagging.
Hawken
  • 131
    The UK is in Europe, and we use flat prongs, though much more substantial and robust than USA's flat prongs. I have always assumed it is partly historical, and partly economics. – gbulmer Sep 25 '14 at 00:15
Flat pins can be made more cheaply- by stamping from sheet using simple or progressive dies- than round pins, which tend to require a relatively expensive screw-machine turning operation from rod.
But really the main advantage is that whichever you pick, it fits the millions of mating receptacles in the target market.
Spehro Pefhany
  • 376,485
  • 842
    According to [this page](http://electronics.stackexchange.com/questions/91844/round-female-pin-header-vs-square-female-pin-header), round pins make better contact and a more secure fit. – Cees Timmerman Mar 31 '16 at 11:19
First, there is certainly a lot of historical legacy.
Round prongs can be more easily isolated, with metal only on the tip, so they are probably safer. (typical example : flat molded plastic "europlug" http://en.wikipedia.org/wiki/Europlug)
TEMLIB
  • 3,347
