I am making a project using at89c51. I used my mobile charger (output: 5V, 1A) as the power supply. Will my IC get damaged due to the high current?
I asked cause, without loading the program I connected the pin40(Vcc) and pin20(gnd) just to check whether all the port pins except port0 give output 1 or not, which is as I believe by default. And I got haphazard values which changed everytime I turned the supply off and on.
I also couldn't find the supply current range in the datasheet so got more confused.
Please advise.
