I just bought a guitar amp that can be powered by a 9v battery or a 9v power supply. The instructions that came with the amp specify that the power supply should deliver 300mA maximum. As far as I understand, the load determines how much current is drawn, so why would it be dangerous to use a power supply with say, 1A? I don't want to fry the amp, but I also don't want to go track down a different supply.
Here's my guess. I think it's probably not safe. I noticed that when I turned the volume up while using a 9v battery, playing a note loudly would cause the amp to die for a moment, which I assume means it's trying to draw more current than the battery can supply. This seems to imply that louder volume equals more current draw from the power source. If I plug in a power supply with a current rating of higher than 300mA, there's the possibility that the amp will attempt to draw in more current than it can handle when playing loudly and fry itself. Is this what's going on?
