Something better than HCMOS: NXP's Advanced Ultra-low Power (AUP) series. I'll presume you have a 32.768 kHz clock and want prescalers/counters to get 1 Hz from it.
The AUP series is not as extended as the HCMOS but the 74AUP2G80 may be all we need. It contains two D-flip-flops with inverted Q outputs, so that we can make a :2 divider. There's no Q output but that doesn't matter.
To divide by 2\$^{15}\$ we'll need 8 devices, that's a supply current of 4 µA maximum (0.5 µA per device). Dynamic power dissipation depends on the supply voltage, and since we want low power we choose the lowest possible: 0.8 V.
Then dynamic power dissipation is given by
C\$_{PD}\$ is power dissipation capacitance and is 1.8 pF at 0.8 V. Then we have
\$ P_D = 1.8 \times 0.8^2 \times 0.032768 \times 1 + (2 \times 0.6) \times 0.8^2 \times 0.016384 = 0.050 \mu W \$
The two times 0.6 pF is the load of the D input of the current FF plus that of the D input of the next stage. The power of the next stage is half this one's, since only the frequencies are halved, the rest is the same. So that's 0.025 µW for the 16.384:2 stage, and so on. The sum for 15 stages is 0.101 µF. (Binary people don't need a calculator for this: N + N/2 + N/4 + N/8 + ... = 2N). Add the static power of 4 µA \$\times\$ 0.8 V and we have a total of 3.3 µW, which is almost 2 orders of magnitude better than the 192 µA with the HCMOS devices (see my other answer).
