I'm a total newbie fooling around with a project of mine.
I want to use an MCP23017 I2C port extender (Data sheet) for my Arduino project.
The chip has three hardware pins that must be externally biased.
I apologize if the question is silly, but, can I just connect the pins to V+ or GND, or do I need to put a resistor in series to limit the current? I looked around a bit but I wasn't able to find an answer.
guyfleeman
  • 155
garph0
  • 185
Yes you can directly connect these pins to GND or V+.
The reason you did not find this explicitly stated is that it is standard that a high-impedance digital input can be connected directly to a logical 0 or 1. When a resistor was needed this would be stated explicitly.
Using a resistor instead of a hard connection might be convenient when you need to change the address on a finished PCB: you can short the pin to the opposite supply rail without damaging anything.
Wouter van Ooijen
  • 48,407
  • 63
  • 136
  • _"Using a resistor instead of a hard connection might be convenient..."_ This is often a zero-ohm link/resistor which doesn't impose significant resistance but is useful for its standard form factor. – Benjamin Crawford Ctrl-Alt-Tut May 08 '20 at 19:58
