-1
I'm interested in finding an oscillator circuit that meets the following constraints:
  • Runs on 9 volts or less
  • Periodicity 100-1000 Hz or so
  • Non-sinusoidal oscillation
  • No inductors
  • 1 transistor or diode
  • Caps/resistors as necessary, as few as possible
  • All components easily available, like what you'd find at Radio Shack
Why do I care about these constraints? I'm a weirdo. (Sinusoids are "prosaic". Inductors are "messy". 2 transistors is "cheating".)
I found this, but is there something even simpler? (I think this is a sinusoidal oscillator anyway.)
MackTuesday
  • 121
  • -1 and you don't say why? – MackTuesday Aug 18 '14 at 02:27
    To put it more politely, the reasons you give for your requirements are not engineering reasons. So you are not asking about engineering, you are just making up a puzzle. – The Photon Aug 18 '14 at 02:33
  • :-/ It's more than just a musing. I want to build one, and it would be a useful stepping-off point for building more complex circuits. – MackTuesday Aug 18 '14 at 02:33
    This question appears to be off-topic because a complete circuit is required. – Leon Heller Aug 18 '14 at 06:10
    Where in the help section does it say a complete circuit request is off-topic? If you guys are going to be picky, you need to put a warning in your help section reading, "Warning: We're Picky". Don't have a help section that pretends to be inviting if the rest of you aren't going to be. – MackTuesday Aug 18 '14 at 15:06
  • Simple circuit revisions or suggestions are certainly possible, but complete circuits or schematics aren't going to be something that *volunteers* will readily supply. – JYelton Aug 19 '14 at 22:49
Probably everyone knows about this 3-component oscillator- but it's hardly suitable for any serious application.
Spehro Pefhany
  • 376,485
  • 842
  • I'm guessing that the cap charges, Q1 reaches the threshold voltage, and then it discharges, repeat. My question is how? Since current can't flow out of the base, I can understand it temporarily turning on, but then the base voltage would rise until it gets to 15-Veb. I'm obviously missing some trick with this setup. – horta Aug 18 '14 at 04:06
    @horta it's not really a trick- the EB junction will typically avalanche (reverse breakdown is usually around 9V) and give you an sawtooth at the capacitor. It's like using undocumented op codes - not a great idea except for entertainment purposes. Breaking down that junction also degrades the forward beta of the transistor so throw it away afterwards. – Spehro Pefhany Aug 18 '14 at 04:18
  • It is called a Esaki oscillator after its inventor Leona Esaki – jippie Aug 18 '14 at 05:32
  • @jippie I only see one non-tunnel-diode reference to that name, and it's another jippie post on ese. – Spehro Pefhany Aug 18 '14 at 14:35
How about a unijunction (relaxation) oscillator e.g. 2N2646 enter image description here
See http://baec.tripod.com/DEC90/uni_tran.htm for design details
JIm Dearden
  • 18,926
  • 30
  • 40
