I know someone else has made a Bluetooth transmitter to a relay so i wanted to ask a few questions about it being possible? I am an almost newbie at electronics but i do know a few things, so first of all I want to power my ATtiny85 from wall power because i want my ATtiny85 inside the wall of my house to control the roof light and i want it to be powered always how would i do that? Second is it possible to switch a 220V AC relay from the ATtiny85 if not would i be better off with an arduino? Thanx
dan14941
  • 125
  • [one](http://electronics.stackexchange.com/questions/25673/driving-a-relay-directly-with-a-microcontroller), [two](http://electronics.stackexchange.com/questions/59456/driving-a-relay-with-transistor-and-opto-isolator) and [three](http://electronics.stackexchange.com/questions/51522/how-can-i-drive-a-12v-automotive-relay-with-a-uc-running-on-5v). – Vladimir Cravero Aug 17 '14 at 12:58
Yes it is possible.
If you buy a module like HC-05, that needs two pins, TX (Transmit) and RX (Receive).
Example: http://arduinofy.blogspot.se/2013/05/attiny-bluetooth.html
Yes, you need a driver since most 5volt relay needs more current than a ATtiny can handle. A Relay driver is just a couple of discrete components.
Example:
Use the search words "arduino mosfet relay driver" at your favorite search engine and you will find what you are searching for.
No, only if you need more memory and pins.
And as a addon: If you plan to control it from an Android I can recommend "App Inventor form MIT" to program your app or you can have a look at mine ;-)
MatsK
  • 738
  • Ohh, missed the power source. I would have dissembled something like this http://goo.gl/9eGqUE as a 5volt power supply. – MatsK Aug 17 '14 at 16:05
  • do I need a relay driver for this relay? http://www.ebay.com.au/itm/201151106679 – dan14941 Aug 17 '14 at 23:31
  • No there is a relay driver included on the board. http://imgs.inkfrog.com/pix/ebayimage2012/26074-7.jpg – MatsK Aug 18 '14 at 00:13
  • Could you make a simple circuit diagram of how I set it up possibly? And do I need extra power for the relay and can I leave the bluetooth module plugged in 24/7? – dan14941 Aug 18 '14 at 07:57
  • `Could you make a simple circuit diagram of how I set it up possibly?` When you ask it like that I would recommend that you start with a Arduino, a relay shield and a Bluetooth shield. `And do I need extra power for the relay` No `and can I leave the bluetooth module plugged in 24/7` Yes – MatsK Aug 18 '14 at 20:21
  • Can't I just use the relay not a relay shield? The one from eBay. And do I need extra power for it? – dan14941 Aug 29 '14 at 09:27
