My question involves chassis grounding to earth ground.
My PCB circuit is a simple signal generator using a microcontroller. It has a separate 'ground' from earth ground, supplied by a floating 5VDC source. (I guess we would call this a digital ground?)
The PCB is to be installed inside a metal chassis (aluminum, I believe). Inside, there is a 15VDC converter. As a signal generator, it outputs a signal with reference to the +5V.
Unfortunately, the device that uses this output signal is grounded to the earth ground, not the digital ground.
The signal, which is supposed to drive a motor, ends up having severe noise problems.
What I found out was that if I provide the chassis (not the circuit ground) a capacitative ground to the earth ground by connecting a capacitor from the chassis to the earth ground pin, the noise problem disappears. However, if I connect the earth ground DIRECTLY to the chassis, the circuit is shorted.
So my question would be, is it normal/safe to ground the chassis of a circuit with digital ground using only a capacitor? If not, is there a better way to fix the noise issue?
Also, even with the capacitor to the earth ground, whenever a large machinery sharing the same earth ground turns on, my device shorts for an instant, and resets the microcontroller. Is this caused by a large current draw from the big machinery? But how so, if only the earth ground is common?
Funkyguy
  • 3,558
  • 45
mineralwasser
  • 161
    I doubt your device is shorting for an instant when other machinery is turned on. More than likely it's getting a power droop which causes your uC to reset. The way to fix that would be to add bypass caps near your uC so that he has a local reservoir of power. Also a basic schematic describing what you're talking about would help. You should also add whether or not you're needing isolation and where you want isolation. Connecting a capacitor between chassis and earth ground is a good way to break all isolation rules (unless it's rated for it). – horta Aug 04 '14 at 14:20
  • What voltage is normally present between chassis and earth ground? 5V? – Spehro Pefhany Aug 04 '14 at 15:33
  • Sphero, that is a very good question! I have not measured that yet. I will do that right now and report back :) – mineralwasser Aug 05 '14 at 07:08
  • Turns out, the chassis has ~80VAC when not grounded (btw, I'm in Germany). – mineralwasser Aug 06 '14 at 08:26
After some experimentation, I found out that it is indeed okay to have capacitative coupling between chassis and earth ground. In the question, I wrote,
This is not true, and it was actually caused by me shorting the 5V supply accidentally.
There were several problems at hand. First, my DC voltage supply was isolated and floating off some weird value. This meant that the 'negative' of the supply wasn't actually connected to the earth ground. As stated in the question, I wanted to drive a motor that was connected to earth ground. Fortunately, the motor only required a differential voltage, hence it functioned okay.
Another issue was the microcontroller resetting whenever a large machinery turned on. This was solved by putting bypass capacitors between all VCC and GND connections (even for the LCD screen that I have as well). Thanks to @Horta for the suggestion! Although, it still is a mystery to me why there was voltage fluctuation within the earth ground in the first place.
Thank you everyone for your help!
mineralwasser
  • 161
if you are concerned about noise interference, use decoupling capacitors as follows:
Let's discuss an audio amplifier with power supply, assembled in a metal box. The power supply consists of a transformer powered with 120Vrms HOT and NEUTRAL. The metal transformer is bolted to the metal cabinet. Metal of the transformer touches the metal cabinet. The ground of the AC input is wire-connected to the metal chassis. The secondary of the transformer has 2 windings (with a center tap). A full wave rectifier is used to get +55Vdc, middle winding is common=0Vdc, and -55Vdc. These voltages power the amplifier. The amplifier LEFT channel uses +55 (common=0Vdc) and -55. A speaker has a red and black wire, with a RED/BLK connector. The output of the amplifier is AUDIO OUT; (the red wire goes to the red connector of the speaker and the common=0Vdc goes to the black connector of the speaker. Same description applies to the right channel. To minimize OVERALL noise, use a metal film 0.15 uF capacitor on the following locations: capacitor between +55V to chassis, +55 to 0Vdc-common, -55 to chassis, -55 to common, and one capacitor between common and chassis. These capacitors help dissipate high frequency noise to chassis (aka chassis GROUND). Use a good multimeter to measure isolation resistance across each capacitor; it should be high (~ 2 meg), which includes the capacitor in parallel with the resistive measurement (+55V to chassis, +55 to 0Vdc, -55 to chassis, -55 to 0Vdc, and 0Vdc to chassis)
Cesar
