I have multiple generators that are producing a variable DC voltage between 0 and 18volts each that are being sent to an inverter for an AC output used to power various devices.
I really need to be able to transmit an audio signal back to each of the generators, and would really like to avoid having to add additional wires. Would it be possible to piggyback an audio signal of a usable quality over these variable DC lines?
I've searched around and suspect this answer might be appropriate, but they're mostly talking about communication signals, and I'm not sure if the required fidelity for an audio signal would be possible. I'm also not sure the effect a highly variable DC voltage would cause.
Thanks
