What's the cheapest way to detect vibration with Arduino?
What's the vibration sensor that I need?
I want to detect PING PONG NET vibration and light on led if touched.
elp
  • 202
Piezo sensors are cheap, reliable and designed for the purpose you suggest - arduino tutorial
In the uk, bitsbox has one for 75p. You can probably find others cheaper, or salvage from electronic toys.
EDIT following poster's clarification of use: Sound is vibration through the air, I see no reason why a piezo sensor cannot accomplish what you suggest, but the form factor may not be ideal for fixing to ping pong nets! I think a flex sensor would be more suitable, sewn into the top of the net.
fearoffours
  • 548
  • Can i use piezo to detect if the ball touch or not the pingpong net? Or it detect only vibration sound? – elp Mar 29 '11 at 12:40
A cheap vibration sensor such as SW-18010P consisting of a fine spring wire coiled around a rigid wire in a sealed package may well be sensitive enough. They act as a momentary switch contact when jolted, and cost a few pennies.
Pete Kirkham
  • 1,976
An optical or magnetic sensor mounted mid net, bottom edge might be a good way to acomplish this. Might also detect vibrations in the table, as might any sensor.
russ_hensel
  • 2,904
You may be interested in how to create a simple circuit using a piezo element and Arduino Uno that can detect vibration with high sensitivity http://davidhoulding.blogspot.com/2014/11/advanced-high-sensitivity-vibration.html Have fun.
yrls2
