I just modelled a P-Channel MOSFET in Eagle and now would like to do duplicate the device to make slight changes to both the symbol and the device for a similar N-Channel MOSFET.
I've searched and googled but I can't seem to find a way to copy the entire device to do this.
MikeFoxtrot
  • 663
  • As far as I know, you can duplicate a symbol (selecting the group command, then enclosing the entire symbol with a rectangle, then selecting a copy command; then creating a new symbol and doing a paste). But you can't do this for a device; there is no copy or paste commands in the toolbar for a device. So you have to take your new symbol, make a new device, and reassign a package and pins to it. – tcrosley Jul 08 '14 at 21:43
To create the new symbol:
  1. Go to the library.
  2. Create a new symbol for the N channel FET.
  3. Go to the symbol for the P channel FET.
  4. Group all of it, then do CUT.
  5. Go back to the new N channel symbol.
  6. PASTE
  7. Modify from there.
Then create the new N channel device, referencing the new symbol.
Olin Lathrop
  • 310,974
  • 428
  • 915
  • Olin is correct. In case anyone is confused, the CUT command in Eagle acts more like a COPY :) – bitsmack Jul 09 '14 at 00:03
  • @bitsmack: Yes, Eagle has some strange command names. As you mentioned CUT does a COPY, and the actual COPY rarely does anything useful. Another one is how WIRE is used to draw lines except when they represent wires, then you have to use NET. – Olin Lathrop Jul 09 '14 at 11:39
