I'm doing a small board with a 915 MHz transceiver. A small helical antenna is used, which is located on board with a very short path (10 mm) from the IC, including balun and a matching network. There are no RF connectors or real state available to include any. Since I'm constrained with the board space and the board needs a plastic case, I couldn't follow the manufacturer's guidelines for them so I need to at least do some antenna matching to ensure maximum transfer. The problem is that I don't have access to a network analyzer, so I'd like to know if there is some manual method I could use, besides randomly trying L and C values and measure the output. I don't need serious antenna performance, but some reasonably "good" one (a relative term, I know).
The board has footprints for two 0402 components, one series and one parallel. IC's crude power output is around 20 dBm. From the IC's development kit I've got boards that have a good antenna and good matching for it (other kind of antenna). I was thinking I could do some continous transmission from my board and get a relative power measurement from the dev kit receiver's perceived RSSI. I could compare the results with measures obtained from another dev kit board in countinuous transmission. Then I would perform some brute force by trying out L and C values. I could also choose from 10 different channels in the 915 MHz band (902~928) and see what diference I get. I know that's terrible, but hey, that's why it's called brute force.
Is there a better method? Is there any cheap (<$100) equipment I could use to get some measurements? Please mind that I live in an underdeveloped country so "buy some xxx on eBay" is not within my possibilities.
Any suggestions would be greatly appreciated.
Adam Haun
  • 21,331
  • 50
  • 91
user44206
  • 81
  • One user gave an answer to this question but it seems it was deleted when the server was put on maintenance. A pity. – user44206 Jun 09 '14 at 01:47
  • Correct to assume you have no spectrum analyzer or 1GHz signal generator? Can you post an image of the reference design compared to your design? I had a hard time understanding what was different. What guidelines specifically didn't you follow? – user6972 Jun 14 '14 at 04:47
  • @user6972 The reference design is completely different as [it uses a whip antenna](http://www.adaptivemodules.co.uk/images/uploaded/WDB%20A1281%20PN%20B%20atmel.JPG). My design has a different shape and uses an [helicoidal antenna](http://media.digikey.com/Photos/Pulse%20Photos/W3113.JPG). – user44206 Jun 16 '14 at 14:00
Without more information about your design I can't comment on the matching techniques. But here is some help for your test setup.
You can attempt to make relative measurements, but RSSI is a poor parameter for verification because you have to make sure you're in the linear range of the RSSI for the comparisons to be somewhat similar. Be aware that RSSI is just a current measurement of how saturated the amplifiers are and in general is not very accurate.
A spectrum analyzer would tell you much more and be able to give you a quick idea of how your device performs across the band.
Barring all that...you'll need to test this in an open area, outside, to avoid multipath interference. The more open and lacking of objects (especially metal), the better. Make two movable test stands (plastic or fiberglass is best) with batteries for power. Measure the distance between your reference receiver and your test transmitter (DUT).
Start with the manufacturers reference and characterize it at low/mid/high bands. Make sure your RSSI readings are stable and your background measurements (with no transmitter in operation) are quiet. The ISM900MHz band can be very noisey, so be careful of false readings using RSSI. You might find you're constantly turning on and off the transmitter to check background levels.
The RSSI needs to be in about the middle of it's range. If it is not, move the units closer or further apart. Measure this distance carefully so you can repeat it in the future...and don't loose your reference receiver! Also keep track of the orientations used and make sure the cables are carefully laid out, taped down for repeatability (both receiver and DUT). You might even want to lay down some copper screen material under the receiver and DUT to provide a more consistent ground plane for testing. Try to run the wires down through the center of the screen under the device.
Then take your design at the same distance and repeat the measurements across the band. With RSSI +/-3 dB is probably about all the accuracy you could expect. And since your design is physically different you might need to test a variety of orientations to insure you're getting consistent results and not testing at some antenna null or lobe.
user6972
  • 1,517
  • Hi, this is great info for the actual test. I however was looking for some insight for determining what changes should I introduce based on the test results. E.g., should I add a capacitor/inductor in series? What value? What would be the range I should be working with? 1~10pF? 10~100pF? 1~100µH? Any hints about that would be extremely helpful. – user44206 Jun 16 '14 at 14:02
  • @user44206 No. It's next to impossible to guess without a network analyzer, or a signal generator and spectrum analyzer. Do you have S11 plots of the two antennas? – user6972 Jun 19 '14 at 17:47
  • I've only got the graphs in the data sheets. S11 is not provided, but I think S11 would depend on my board geometry, case, etc.? – user44206 Jun 19 '14 at 19:20
  • @user44206 Yes the final S11 with the match in place and new antenna. But S11 of each antenna is a starting point you need to know to do the proper match. Vendors usually provide S11 plots for their antennas. You might have to call around to get the data from them. Comparing the two S11's of the two antennas might be helpful in trying to guess at new matching values. Also knowing the output impedance of the amplifier would be very helpful. – user6972 Jun 23 '14 at 07:44
  • thank you. In about three weeks the boards will be in my hands. I'll make some crude measurements by then, so for the moment I'll try to keep my worries at bay. BTW, as a "neutral" series element I'll be using a 0402 100pF C0G capacitor; what do you think? Would that be neutral enough? Worst case scenario I could replace it by a solder bulge. :P – user44206 Jun 24 '14 at 00:22
Ok, the poor mans alternative is the following:
Directly connect the antenna (maybe with a 0 Ohms resistor) to the driver and do not use the matching network.
You may loose ~3dBs, but usually that‘s not much compared to the antenna loss and path loss.
Stefan Wyss
  • 6,471
