29
I purchased a few fuses to get familiar with their workings, and I was surprised to see that the 100mA fast-blowing fuses I bought happily conducted up to 215mA (6V power supply, 10\$\Omega\$ resistor), where the filament just started glowing. I could reproduce this with a second fuse.
Am I gravely misunderstanding something here, or is this an issue with the fuses? They are Bel Fuse Inc. 5SF 100-R parts.
Vladimir Cravero
  • 16,007
  • 38
  • 71
Duoran
  • 602
Even fast fuses don't respond immediately after the rated current is reached. Most fuses require a significant over current to fire almost instantly. This is an obvious requirement since its all about heat, and minor heating (a raise ambient temperature) shouldn't affect the fuse too much (or at least not cause it to "blow").
Judging from the data-sheet, your 100mA fuse should blow after about 80 seconds @215mA @25°C.
How long did you wait?
Rev
  • 10,017
  • 40
  • 77
    Oh, I get it now! I only waited a few seconds, as I expected a somewhat instant failure @100mA. This wrong assumption also led me to completely misread the datasheet. Thanks! – Duoran Jun 05 '14 at 12:21
    A semiconductor protected by a fast acting fuse, protects the fuse by blowing first. I forget where I read that, but it's stayed with me ever since... –  Jun 05 '14 at 22:41
  • @The Blue Dog: more often that not, the semiconductor fails first, but in a short circuit mode; and then the fuse (or/and another component) blows. – fgrieu Jun 06 '14 at 12:17
  • @fgrieu: A few people got the joke, you obviously didn't. –  Jun 06 '14 at 16:51
    @TheBlueDog: I do get the irony that the semiconductor protects what's supposed to be its protection (my remark shows we can't even count on salvaging the fuse after the expensive semi gets fried!). If there's another aspect to the joke (like a double meaning for _blow_), no I do not get it. – fgrieu Jun 06 '14 at 17:06
Glass fuses, especially at very low ratings, aren't really meant to be that precise. You cannot, for example, just inline a 2N3904 with a 200 mA fuse and expect it to protect the transistor in all circumstances. You would, after all, expect it to NOT blow at 190 mA. In this example, you would probably want to over-specify the transistor and use a fuse at double the maximum expected load. If the user does something silly, like shorting the output, the fuse will do its job.
Peter Mortensen
  • 1,676
paul
  • 2,083
This may give some clue, only posting here as I happened to be reading the source:
There were two main types of rating used for fuses. The nominal rating which is the current the fuse will carry for 1000 hours without failing at a temp of 20 degrees centigrade. The service rating is the current the fuse will carry for 1000 hours without failing at a temperature of 100 degrees centigrade. The service rating is 80% of the nominal rating. E.g. a fuse with a nominal rating of 10 amps has a service rating of 8 amps. Confusion arose when the equipment in use before 1962 would quote either of the ratings. (EMER General O 001, 1962).
Of course, there is a relatively unknown online reference known as Wikipedia which has some potentially helpful hints too.
John U
  • 7,041
