I have a IR Line Laser with following Specs
Output Power : 60mw
Wavelength : 780nm
Working Voltage : 5.0VDC
Working Current : <200mA
Laser Shape Line
for details please visit the link http://www.aliexpress.com/item/60mw-780nm-Infrared-Laser-Line-Module-120-degrees/1517656084.html
i would like to power this device using a USB port via a cable. iknow USB has an output voltage 5V but isnt it 500mA ?? Some say Device draws only required current from USB port
My question is can i directly connect laser to USB port by cutting a USB cable? Or should i convert 500mA to 200mA? If so how can i do it ? Can someone specify a solution?
Thanks in Advance
