I am designing a power supply for a docking station, however I'm struggling to determine what value capacitor I will need? The transformer I am going to use is:http://uk.farnell.com/carel/tra12un100/transformer-240vac-in-12vac-out/dp/645400
I need a voltage regulator of 12V also and a current of 5A to power 2 separate circuits?
If you need some more information please don't hesitate to ask :)
user43010
    possible duplicates: http://electronics.stackexchange.com/questions/73863/cap-value-for-full-wave-rectifier-circuit http://electronics.stackexchange.com/questions/101611/how-to-find-the-values-of-capacitors-required-for-power-supply-circuit make sure that you are not asking the same. – nidhin May 18 '14 at 13:30
Update: I checked that link and it seems you want to use a 3 VA transformer to make a 60 VA supply !? You'll need a transformer of 75-80 VA.
First of all, a voltage regulator at 5A produces a lot of unnecessary heat.
Sticking to your design, I'll assume the voltage regulator has a drop of maximum 2V accross it. So it must be powered all the time with a minimum voltage of 14V.
So you have that transformer of 12 V RMS AC. After bridge rectifier you get \$12 \cdot \sqrt{2} - 2 \cdot 0.7 = 15.57V_{p-p}\$. This voltage should never drop below 14V. This means a maximum ripple of 15.57-14 = 1.57V. For even better reliability I'll approximate this to 1.5V.
Now the capacitor value is \$C = {I \over {2fV_r}} = {5 \over {2 \cdot 50 \cdot 1.5}} = 0.033 F = 33000 uF\$.
This high value makes your transformer unusable for this design. Now that you know how to calculate this, choose a transformer with higher output voltage so that the filter capacitor will have a smaller value.
Cornelius
  • 5,048
  • 26
  • 45
  • I am really struggling with this design! what design would you use personally, I am relatively new to design, any more help you can offer will be greatly appreciated. – user43010 May 18 '14 at 14:33
    Get a SMPS kit like this suggested in the other answer http://uk.farnell.com/artesyn-embedded-technologies/nps63-m/psu-open-frame-12v-60w/dp/1886194?ref=lookahead – Cornelius May 18 '14 at 14:48
    +1 for "just buy an SMPS", life is too short to reinvent every wheel unless there is a good reason (good reasons can include "for the hell of it"). Many minds far greater than ours have put a lot of effort into SMPS design so you can buy something safe, reliable, efficient and cheap from Farnell for 100x less than you'll spend in time wasted trying to whittle your own. If you just need **some +12v** use any old ATX PC power supply for peanuts, see dangerous prototypes website for how to wire them up. – John U Jun 17 '14 at 18:17
