After getting some ideas (thanks to users Russell McMahon, akellyirl, The Photon...) and some extra research and redesign, I would like to hear opinions about how to approach my LED flash project. Thanks.
I want to use 240 High CRI LEDs to build a LED flash ligh for camera shooting. There will be 6 camera shots delayed 500ms among them. So the LEDs will be turned on 6 times each 500ms for a duration of just 3ms. The same sensor triggers the camera shot and the LEDs.
These LEDs come in strips of 1m (versions 12V and 24V available), each of them carring 60 LEDs. So 4 strips are needed.
Within 1 strip (24V version), the 60 LEDs are distributed in 10 parallel groups (according to specs "60 LED pcs / meter, cuttable every six (24V) LEDs"). Each of these groups takes 24V and has 6 LED units in series along with some resistors in order to have the 120mA flowing through each 6-LED group (specs doesn´t explicitly say so but I think it´s the way).
I´m planning to connect the four 60-LEDs strips in parallel so I´ll have 40 groups of [6LED + resistor in series] connected in parallel. I want to power up the strips with a Constant Current PSU adjusted at (120 mA * 10groups) * 4stripes = 4.8 A
(I know I may have trouble if one series group fail so I could get higher current flowing through the rest, but I´ll probably make use of this solution)
Here comes the problem, since the LEDs have to light just 3ms at full power in the precise moment, I´m wondering if the PSU will be able to deliver the power right in the instant needed or if I will have issues related to the Transient Response of the PSU. Does anybody know about this?
In case the power couldn´t be delivered within the time contraints that I need, I was thinking about using capacitors. How the scheme would be in this case?
Any ideas are welcome
Thanks
Nicolai
  • 141
  • "So the LEDs will be turned on 6 times each 500ms for a duration of just 3ms." Do you mean 500 µs ? – tcrosley May 13 '14 at 14:22
  • The strip is designed for 24W at 24V and 1M, which is 1 Amp at 24V. 100mA per segment? – Passerby May 13 '14 at 14:50
  • @tcrosley I think they actually mean flash 6 times in 3 seconds. – Passerby May 13 '14 at 14:52
  • The LEDs are turned on an amount of time of 3ms every time the camera shoots. This happens 6 times, every 500ms. I.e. the camera shoots one time every 500ms until it completes the 6 shots. – Nicolai May 13 '14 at 15:04
Note: Some of the information below is anecdotal, since my measurements use a Canon 1D Mark III dSLR, rather than specific light-sensing instrumentation
I've just started work on a strobe softbox for my own product photography studio use, especially motion capture (multiple exposure of moving parts in a single frame): I will be using RGB LED strips to get color control.
Couple of things to note:
  1. If you have 12 Volt or 24 Volt LED strips, those already incorporate the current limiting resistors in each cut-able piece, so you do not need current limiting - Just provide the rated voltage.
  2. A 3 millisecond strobe every 500 ms is trivial to achieve with most LED power supplies and LED strips: I have been experimenting with a 40-Watt LED power supply, using MOSFETs to switch power to the R, G and B lines, and I am able to achieve strobe duration reliably down to 2 strobes in 1/8000 second (0.125 milliseconds).
My results get muddy below around 30 microseconds per strobe. My camera does not support a shorter shutter time than 1/8000, so I cannot capture more precise data.
Lessons learnt:
  • A 24 Watt power supply used on a 24 Watt LED strip leads to spurious pulses during the time my shutter is open, but a supply with at least double the LED strip's rated power works fine.
  • Minimum clean strobe duration varies widely between LED strips of different manufacturers, and slightly between different LED strips from a single manufacturer.
  • Pulse edges get softer due to capacitance along the conductors, as the length of the LED strip increases, so connecting lots of the "cuttable" cut pieces in parallel works better.
  • The green intensity needs to be reduced a lot compared to the other two, the red a bit lower than the blue, else a color cast appears.
  • The green needs to have duration reduced by about 0.25-0.5 microseconds compared to the other two colors, which may be due to secondary phosphor afterglow: See this answer for a detailed discussion on the "long tail" subject.
The last two points are not applicable if white LEDs are used. However, white LEDs will have a slight color cast when using very short duration (say less than 0.1 millisecond, exact limit depends on specific LED used) strobes, due to the yellow-emitting secondary phosphor continuing to glow after the blue / UV junction emission stops at each pulse. At 3 millisecond strobes this color cast will not be discernible.
Recommendation:
Experiment with the specific LED strip you intend to use, to determine the point at which any shorter strobe duration causes a color cast. The figures should be far shorter than the 3ms specified in the question.
Anindo Ghosh
  • 50,188
  • 103
  • 200
