Refer to this question I had asked a few days back: PWM DAC Filter explanation
Hi, It is getting extremely difficult for me to create the PT0 and PT1 signals as given above. I am using a dsPIC30F device. Two PWMs are created with independent duty cycle control, however, the duty cycle change happens by controlling falling edge, where as the above demands that PT0 must have fixed falling edge and variable rising edge...how to achieve that?
On the other hand, I am thinking of using a simple 4th order sallen-key LPF to filter out most of the PWM fundamental...and set its cut-off to say less than half of the PWM fundamental. My sampling frequency for the DAC output (yes, I am sampling my own DAC output) is LOW about once in every 25ms.
Can I remove the left over ripple, by using a small LC filter in line with the DAC output...this works in voltage regulators...will it work here. The output is going to drive a high input impedance OpAmp...so current drive capacity is not in question.
Any pointers?
