I'm trying to get to know my PIC with simple 'start-up' projects. I made a LED flash with a button. I made a BCD count up from 0 to 9 with a delay.
Now I want to combine those two and also refractor the code a bit. So I want the BCD to increment on each button push. Ideally that would use an interupt, but not necessary for this aplication. Next step would be use the interupt and have two inputs (for up or down) and then swap the buttons for a rortary encoder.
The questions I have are:
- where should I 'store' the current value on off the BCD? a global var in main?
- why do I get this type redeclared error and function declared implicit int warning?
The BCD is on PORTA, the input (active low) is on PORTB.RB0 These are the two progams that actually work:
void main(void)
/* Configure the oscillator for the device */
ConfigureOscillator();
/* Initialize I/O and Peripherals for application */
InitApp();
while(1)
if (PORTBbits.RB0 == 0){
PORTAbits.RA2 = 1;
} else {
PORTAbits.RA2 = 0;
Note that RA2 would be connected to a normal LED. And for the counter:
void main(void)
InitApp();
// lookup table for BCD
const uint8_t pat7seg[10] = {
// RA0:6 = ABCDEFG
// RA7:0 = FG-EDCBA
0b01000000, // 0
0b11111001, // 1
0b10000100, // 2
0b10010000, // 3
0b00011001, // 4
0b00010010, // 5
0b00000010, // 6
0b11111000, // 7
0b00000000, // 8
0b00010000, // 9
// current digit
uint8_t digit;
digit = 0;
while(1)
for(digit = 0; digit < 10; digit++){
PORTA = pat7seg[digit];
__delay_ms(2000);
So I tried to 'combine' these like:
void main(void)
InitApp();
// current digit
uint8_t digit;
digit = 0;
while(1)
/* TODO <INSERT USER APPLICATION CODE HERE> */
/*for(digit = 0; digit < 10; digit++){
__delay_ms(2000);
digit = updateBCD(digit);
uint8_t updateBCD(uint8_t myCount) {
/* define constant for lookup BCD */
// common anode so, inverted
// RA0:6 = ABCDEFG
// RA7:0 = FG-EDCBA
0b01000000, // 0
0b11111001, // 1
0b10000100, // 2
0b10010000, // 3
0b00011001, // 4
0b00010010, // 5
0b00000010, // 6
0b11111000, // 7
0b00000000, // 8
0b00010000, // 9
if (myCount < 9){
myCount++;
} else {
myCount = 0;
PORTA = pat7seg[myCount];
return myCount;
errors: (908) exit status = 1 main.c:46: warning: (361) function declared implicit int make[2]: * [build/XC8_16F628/production/main.p1] Error 1 make[1]: * [.build-conf] Error 2 main.c:52: error: (984) type redeclared make: * [.build-impl] Error 2 main.c:52: error: (1098) conflicting declarations for variable "updateBCD" (main.c:52)
I use a PIC16F628 and MPLAB X IDE 2.00 with XC8 compiler.
Hope you can help.
