So I'm using a PIC32, it's rated for 80 MHz operation. But my crystal might be inaccurate, so it could oscillate at 80.01 MHz. I can presume this is okay, but what if I were to use a 7.3728 MHz crystal and an 11x PLL, would running it at ~81 MHz be okay? I suppose what I'm asking is how far is too far? And why do manufacturers not include a bit of overun (for example rating it at 81 MHz?)
mjh2007
  • 3,899
  • 49
Thomas O
  • 31,546
  • 57
    You can take a closer look at those conditions specified on the data sheet and still be operating the part safely for your application. For instance, if the part is spec'd run at 80 MHz up to 125°C and you plan on running inside where the temperature may never exceed 30°C you'll be fine running at 81 MHz. There is an [interesting article](http://www.eetimes.com/design/signal-processing-dsp/4209479/Go-beyond-the-datasheet--Part-2--Understand-the-considerations) on this subject. – semaj Mar 01 '11 at 16:59
    Also note that you cannot generalize. If that particular chip works at 81 MHz, there's no guarantee the next one will too. – drxzcl Mar 02 '11 at 10:01
Manufacturers specify a maximum clock speed for a reason, as it guarantees correct operation under all conditions specified in the data sheet. Operating a device outside its specification might be OK in a hobbyist application, where an occasional failure can be tolerated, but isn't a good idea if reliability is important. You will have to test the system and see if it is sufficiently reliable for your requirements, under all circumstances.
I can't see 81 MHz causing a problem, but it can't be guaranteed.
Leon Heller
  • 38,774
  • 60
  • 96
Well the right answer is "you can overclock until it stops working" .... more seriously something like bumping an 80MHz clock to 81MHz is not a big deal
(puts on chip designer hat) when we tape out a chip we don't have complete control over what happens at the fab - they might put a little too much dopant (or to little) in one step, or under etch a step so that wires are slightly wider (with higher capacitance) - instead we design for the 'worst case corners of the process' and try and make internal timing there - that way any functional chip coming out the other end should work and meet the spec - from you point of view it means that most of what you get from us is somewhere in the middle of the yield curve and happy to run over spec .... but some percentage will be just at spec and will fail if you overclock (and some percentage will go much faster still).
We don't normally test chips for speed (maybe sometimes a test patch on a dies to test the process) - it's way too expensive - we plan on them all working. Some expensive chips (high end processors for example) will get tested and binned because it makes sense for both practical (yield) and marketing reasons to do so
Taniwha
  • 1,636
    Indeed. Some batches of chips may even overclock better than other. Me and my brother have bought a PC a couple of years back with both a Intel Q6600 CPU. We bought from different shops, and we got different batches (shown on the box). My batch overclocks to 3.2GHz (from 2.4GHz) on a boxed cooler, without adjusting any voltages. My brothers version has to increase voltage above 3GHz. It heavily depends on the batch, fabrication plant, etc. There is no fixed point to hold on to if you're designing with overclocked parts. – Hans Mar 02 '11 at 16:16
In fact, most of these low-speed chips can work on 1.5x frequency in normal conditions, the only problems are at extreme temperatures (like -55 or 125) + flash/EEPROM writing.
So if you you are building device which will be operated at 15-40C range, you may test that it works at 120Mhz and leave at 100 permanently.
Manufacturers underspec devices to increase yeld rates & reduce reclaims.
BarsMonster
  • 3,267
  • 45
  • 79
  • when I used their dsPIC a while back it said its maximum was an absolute maximum, and when trying to go higher my actual clock frequency(effective to the chip) decreased. – Kortuk Mar 02 '11 at 09:21
  • Well, you should have tried feeding raw clock into it without any PLLs and stuff, it would have no chance to avoid overclocking :-D – BarsMonster Mar 02 '11 at 11:28
  • it had built in PLL on the extern clock lines. There was no way around that. – Kortuk Mar 02 '11 at 11:29
  • Ok, then we have artificial obstacle here :-) – BarsMonster Mar 02 '11 at 11:30
If you're working with a single device you can just try and see what frequency still works. 81 MHz will still work, no doubt about it.
It's a bit different if you're working with production quantities. You can't make a production run and hope everything will be all right.
In the early 90's I worked for Philips Audio and we had a design which used a Motorola 56002 DSP running at 27 MHz. This was an audio application, and the 4th harmonic of 27 MHz is 108 MHz, just at the edge of the FM band. Because we feared interference we wanted to run the DSP at 27.1 MHz. Would this work? Yes. For sure? No. Motorola guaranteed it for 27 MHz, no more. We requested and got a custom version of the specification which stated 27.1 MHz as the maximum frequency.
Did we get different, selected devices, or was there a die redesign? Of course not, but in unlikely the event that a DSP would not work Motorola would be liable.
stevenvh
  • 145,145
  • 455
  • 667
Back in the 1970's, it was pretty common to run 6502 microprocessors at above the rated speed, even though the data sheet gave a minimum cycle time of 1000ns for the 1MHz part. The popular Atari 2600 Video Computer System ran its processor at 1.1932MHz; the Apple II, Commodore VIC-20, and Commodore 64, all ran at 1.0227MHz. Since there were no speed grades between 1MHz and 2MHz, I would expect all of those machines were overclocked (by almost 20% in the case of the Atari 2600 Video Computer System).
supercat
  • 45,939
  • 84
  • 143
