I have bought a car camera with LCD monitor, exactly this one http://www.dx.com/p/5-0-lcd-car-rear-view-stand-security-monitor-camera-w-5-ir-led-kit-480-x-272-pixels-153662
It is powered by 12V.
Can I try it out at home by connecting it to my PC power supply? There is 12V available in the molex connector.
Thanks
Yes you can get 12 V from your PC power supply. But you must know how to start it outside of the PC (the PS_ON pin).
Also, most PC PSUs need a load on the +5V voltage to fully start up.
However if you use the PSU while in the PC box, there's no need for load and PS_ON, just be sure to do the wiring with all the devices powered off, to avoid ESD.
For your camera, you need the black wire (GND) and the yellow one (+12V).
Cornelius
  • 5,048
  • 26
  • 45
You can bring out an HDD plug and tap into the 12V on the side of your PC. The two centre pins are ground.
Since it is made for a car, the unit must be designed for abnormal automotive range 11 to 15 V , normally 12.5 to 14.2, so 12 V +/-5% on your PC is ideal.
  • I'd like to mark also your answer, but it's possible to mark only one answer. Thanks! Usefull information. –  Apr 28 '14 at 19:47
