I know I can use a transistor as a switch like this:
Can I use only one transistor that will output the same signal (not inverted)? I want to use it to shift voltage level. The input is digital at 3.3V and should output 5V TTL levels.
Cornelius
  • 5,048
  • 26
  • 45
Absolutely.
This circuit takes advantages of the properties of a MOSFET to bidirectionally switch a signal between two different voltage levels.
Ignacio Vazquez-Abrams
  • 48,282
  • 73
  • 102
20
This circuit tends to be used quite often: -
  • Very interesting. Would it be possible to put one GPIO of a board such Raspberry or BeagleBone at the input without frying the board? What I don't understand is: at the basis you have a constant voltage, the collector is pulled up. So how can you be sure that no current is moving from the 5V to the input? Eventually destroying the driving board? – Dave Jan 23 '16 at 20:37
  • Because the transistor is configured as an emitter follower and the voltage on the emitter is base voltage minus about 0.6V. If the emitter got higher it would turn off the transistor thus preventing the voltage rising much above about 3V. Think of base and emitter and what differential voltage they must be at to stat to turn the transistor on. – Andy aka Jan 23 '16 at 21:41
  • @Andyaka Will this work if we change 5V to 3.3V? – killdaclick Aug 14 '18 at 18:36
  • If you did that you wouldn’t need a level shifter. – Andy aka Aug 14 '18 at 21:22
For this situation you very likely do not need any conversion circuit at all.
Both 3.3 V and 5 V TTL logic switch with a threshold of about 0.8 V. Therefore no conversion circuit is needed to drive a 5 V TTL input with a 3.3 V logic signal. To be absolutely sure, check the minimum Vih of your 5 V TTL device and make sure this number is less than the minimum Voh of your 3.3 V device.
This figure, from the TI app note, "Selecting the Right Level-Translation Solution", shows that the specified input, output, and threshold levels are the same for 5 V and 3.3 V TTL circuits:
If your devices are actually not TTL but CMOS, you may still be able to connect them without a conversion circuit, but noise margin will be reduced because the CMOS switching threshold is Vcc/2 rather than a fixed voltage level.
As you see from the chart, you cannot reliably use a 3.3 V TTL signal (or even 5 V TTL) signal to switch a 5 V CMOS input, so for either of those situations you would need a converter circuit as outlined by the other answers here.
The Photon
  • 126,425
  • 159
  • 304
