I've been googling for about two weeks now and I still can't seem to get my I2C working. I've used this (what seems to be complete) tutorial. I followed the Master Write and Master Read examples to try and read from my sensor. I've referenced the I2C_MASTER.zip and I2C_SLAVE.zip from the Microchip site, and my I2C still does not work. Can I get some tips?
More information:
- SDA, SCL hooked up to PIC18F's SDA1/SCL1, configured for open-drain and wired to supply voltage
- Tried different approaches with IdleI2C1() and EEAckPolling1(address) with no progress
- Followed the Microchip example of checking the collision bit, but still doesn't work
- Using i2c.h from the XC8 Compiler
- SSP1ADD is set to 19, but maybe it's not right? I have my clock running at 8 Mhz with the internal oscillator, and got that value using Fclock = Fosc / (( SSPxADD + 1 ) * 4), where Fclock is 100 kHz and Fosc is 8 Mhz
- I do not have an oscilloscope to view signals
Does anyone know of any libraries I can easily use for reading and writing without worrying about Ack/Nack signals?
Here's the relevant code:
void init()
CloseI2C1();
OpenI2C1(MASTER,SLEW_OFF);
SSP1ADD = 19;
getEEPROM();
void getEEPROM()
static signed char status,data;
IdleI2C1();
StartI2C1();
while(SSPCON2bits.SEN);
do{
status = WriteI2C1(MLX_EEPROM_WRITE);// Signal to EEPROM start point
if(status == -1)
data = SSPBUF;
SSPCON1bits.WCOL = 0;
}while(status!=0);
IdleI2C1();
do{
status = WriteI2C1(0x00);// Signal to EEPROM start point
if(status == -1)
data = SSPBUF;
}while(status!=0);
IdleI2C1();
RestartI2C();
do{
status = WriteI2C1(MLX_EEPROM_READ);// Signal to EEPROM start point
if(status == -1)
data = SSPBUF;
}while(status!=0);
IdleI2C1();
getsI2C1(eepromData,255);
/* // supposed to be the same as getsI2C1
for(i = 0; i < 256; i++)
eepromData[i] = ReadI2C1();
IdleI2C1();
NotAckI2C();
while ( SSPCON2bits.ACKEN );
StopI2C();
while ( SSPCON2bits.PEN );
