I am making some pretty crude devices that are directly powered from solar panels. The instability is not an issue, but I want to avoid over-voltage.
I am using two 100W panels in series and want to make sure on a very (very!!) sunny day it does not exceed 30V.
If I use a 30V Zener diode alone would that be OK? Looking at the power curve am I right to assume there will be no power if a Zener shorts it? Does the panel try to fix the current so the voltage drops?
This is opposite to a constant voltage supply that would make it blow up? Or have I missed the point?
