I'm trying to synthesize an Altera circuit using as few logic elements as possible. Also, embedded multipliers do not count against logic elements, so I should be using them. So far the circuit looks correct in terms of functionality. However, the following module uses a large amount of logic elements. It uses 24 logic elements and I'm not sure why since it should be using 8 + a couple of combinational gates for the case block.
I suspect the adder but I'm not 100% sure. If my suspicion is correct however, is it possible to use multipliers as a simple adder?
module alu #(parameter N = 8)
output logic [N-1:0] alu_res,
input [N-1:0] a,
input [N-1:0] b,
input [1:0] op,
input clk
wire [7:0] dataa, datab;
wire [15:0] result;
// instantiate embedded 8-bit signed multiplier
mult mult8bit (.*);
// assign multiplier operands
assign dataa = a;
assign datab = b;
always_comb
unique case (op)
// LW
2'b00: alu_res = 8'b0;
// ADD
2'b01: alu_res = a + b;
// MUL
2'b10: alu_res = result[2*N-2:N-1]; // a is a fraction
// MOV
2'b11: alu_res = a;
endcase
endmodule
