I want to control multiple baseboard heaters in my house, but I don't want to put a raspberry pi connected to a solid state relay behind each baseboard heater, or even connect it to the thermostat, as the raspi is rather large and it requires a clunky power adapter. Is there a wireless/bluetooth/RF solid state relay which also gets powered by the AC line (208V)? I will have sensors all over the house, I just want to be able to send an ON or OFF signal to these solid state relays without having to have miles of cabling
EDIT: I essentially want to build something like this product, but connecting to the baseboard using wires rather then an electric outlet, and being able to communicate to it through a computer. Also, I don't believe these guys need any other power source (ie. batteries)
puk
  • 121
  • Why can't you just use the MCU in the wifi/BT/Zigbee module to run the SSR? – Ignacio Vazquez-Abrams Mar 09 '14 at 09:01
  • @IgnacioVazquez-Abrams because I have no idea what that is...or what I am doing. I am a programmer, not a hardware guy – puk Mar 09 '14 at 09:37
    There's not really such a thing as a wireless SSR available as a component as far as I know. That device you've linked would most likely contain a microcontroller, RF receiver and probably a kind of power supply that wouldn't be safe apart from the fact it's double-insulated which is why it's so small. – PeterJ Mar 09 '14 at 09:52
  • @PeterJ So is there a way to, for example, control my baseboard without having to use a huge 120 V AC to 5V DC power adaptor? Are there simple small adaptors? I am just trying to wrap my head around the fact that these SSRs always require a large power supply, so it is hard to conceal them in places, like walls – puk Mar 09 '14 at 10:22
  • A slightly related question is [Small AC Transformer](http://electronics.stackexchange.com/questions/102318/small-ac-transformer) but in reality that device probably contains something like [this](http://electronics.stackexchange.com/questions/5572/how-efficient-is-a-capacitive-power-supply) but read all the warnings on the answer, it would be a bad approach for a beginner and hard to make safe. – PeterJ Mar 09 '14 at 10:28
  • @PeterJ I am meeting with my electrician, so I will get him to do all the dangerous stuff – puk Mar 09 '14 at 10:32
Google for EnOcean relay. You should find relays that can handle this. You will need a wireless switch or a EnOcean thermostat to controls them.
FMarion
  • This is exactly what i was looking for. The power supply is 24/120/240/277 VA but I am using 208 VA, I know with baseboard heaters you can feed 208 VA even though it is listed as 240 VA, is it the same with these? – puk Mar 10 '14 at 00:05
    You should be able to find specific devices for 208Vac coil voltage. Like RIBW208B-EN2. I guest a 240Vac model should work at 208Vac... depend on your load. – FMarion Mar 10 '14 at 00:35
  • Any reason why there is no information as to maximum wattage? – puk Mar 10 '14 at 00:42
  • You should at least have the current rating. Your home braker should be 20amp or 15amp ? Try to match both rating. – FMarion Mar 10 '14 at 01:06
  • What about something like this, it seems to be what I want, but I can't find out what the input voltage is http://www.seeedstudio.com/depot/codecadaptive-wireless-relay-p-550.html?cPath=139_140 – puk Mar 10 '14 at 01:15
  • From the picture, the relay is rated 7amp at 250Vac, looks low for me. – FMarion Mar 10 '14 at 01:32
Powerline communications is a possible way to do this. Here is an article from TI (formerly a National semi article) about powerline comms for driving speakers around the house with them connected only to AC. Here are Tx and Rx circuits. Note that this is driving an analogue signal by modulation through the power wiring in a house and detecting and restoring the signal for presentation to a receiving loudspeaker.
This can easily be adapted to some form of simple data modulation for controlling relays.
