I am aware of the JEDEC registered outlines, which define the standard mechanical dimensions and tolerances for a wide variety of solid-state packages.
However, these standards do not appear to cover two-terminal SMT resistors and capacitors (e.g. 0603, 0805, etc.). IPC-SM-782 has dimensions and tolerances for these, but this standard has been superceded by IPC-7351, which no longer includes this data.
What standard currently governs the standard dimensions of these components?
SWB
  • 323
  • I don't think that means the IPC-SM-782 footprints are invalid -- I'd use them. Also I think these are copyrighted documents and while I appreciate the links, a moderator may need to unlink them. – HL-SDK Feb 26 '14 at 20:20
The answer may be IEC 60115-8 for resistors, and IEC 60384-21 and IEC 60384-22 for capacitors.
However, further research suggests that the primary source should actually be EIA PDP-100 – if it were up to date. The latest edition of this appears to be from either 1987 or 1992. There's a convoluted history you can dive into at Wikipedia, JEDEC, and ECIA, but the short story is that the EIA is no more, and the EIA standards are now maintained by the ECIA. There is some evidence that a new edition of PDP-100 has been worked on, but there doesn't appear to be much activity right now.
SWB
  • 323
